Shadows Entity's MK1 stage 2 + r32 setup
Two completely unrelated updates...
Got these b/c pillar trims fresh from Germany and the only set left apparently.... couldn't see them on their website had to ask.
I had CF wrapped them but I had never been that pleased with the results probably because I did it and could see the faults
Also got a Diffuser from Milotec but that's a Christmas present off the GF
Managed to finally get round to doing my brakes to discover I need a caliper rewind tool to do the rears but still did the fronts.... Never changed disks or pads before so was all new to me although I knew what I was doing in theory.
Took me a while but I was in no rush just wanted to do it right first time and figure things out in practice
Hardest bit was getting the carriers off to change the disks as disks get changed less often than pads so the bolts were pretty tight in place but I just used a lump hammer on the spanner to get it moving
Probably didn't need doing but I've never done it before and my disks were an advisory on my MOT as they were highly corroded on the outside and center.
Old
Greased up hub
New and reassembled
So at least now I've done it and I know what I'm doing which will save me money in the long run so has to be worth while :)
Just waiting on the rewind tool I've ordered to do the rears
  • Replies 162
  • Views 23.7k
  • Shadows Entity
    Shadows Entity
    Pictures that Clive sent me when it was in progress         This is what massively delayed me getting my car yesterday....       Yes that is a horse box on it's side and a landrover
  • Shadows Entity
    Shadows Entity
    Got some new wheels thanks to vRSy which imo are millions better and nearly new so not all corroded like my old ones, tyres on them are insane as they're Falken road slicks feels like you could go rou
  • Shadows Entity
    Shadows Entity
    Got the car back yesterday.... doesn't even feel like the same car, Clive has made it into an animal. 5th Gear actually does something now, don't even have to drop down to overtake just a twitch on th
Nice!
I went to do my rears today to fine my rewind tool is missing!  :wall:
I wouldn't of greased the hub (personal opinion) just a drill with a wire brush attachment and a good clean with a scotch pad, the grease could potentially offset the disk slightly.
Just look out for brake judder if you appear to get any at all just the hub face a good clean as above.
I read that you should or it can make taking the disks off next time worse and no brake judder just nice and smooth and a lot less brake travel.
Also surely when you tighten the wheel bolts up it will squeeze any excess grease out anyway and yea gave it a good clean, the hub went from brown to shiny grey
Was just a heads up fella, iv put grease on hubs before and a customer coming back in with brake judder, turned out to be a large rust flake caught in the grease.
Thats what those little disk screws are for  :giggle: to hold the disk in - Granted they are a major pain in the arse! but a hammer and a large phillips tends to get the out
Although for some reason i have got brake judder what pads have you used? im thinking my pads are crap and causing it.
Pagid disks and pads, made sure everything was clean and scrubbed so there'd be no issues... no use spending all that time to only take them off again to sort it
Cheers.
I might get some pagid pads and see how they fair.
getting my rear bumper resprayed tomorrow after it got rubbed up by another car lol so I'll do a before and after picture :)
I need to sort my wing out after someone decided my car needed to get thinner!
Pictures of the before and after bumper respray...
Didn't look this bad when it happened but I gave the car a quick jet wash to get all the loose dirt off which blew loads of flaky paint off... I suspect before I owned it someone had done a cheapo job after reversing into a wall etc... as the spray guy agreed with me that original paint wouldn't come off that easy
And here is after, looks a little odd as the car needs a good waxing to get the original back to it's proper colour but I am pleased with the job :)
Spot on that!
Looks to me like a cheapo job on the first, not enough paint and lacquer or to much thinner. 2nd pick looks a good job.
Just need to get your bump strips black again, some back to black or a rattle can :rock:
yea I do use that stuff but im gonna take them off and plastidip them at some point
already on it my son got me new number plates and surrounds for Christmas
Found some time to give the car a quick clean :)
Like a lot
well got my new front number plate on and also a new vrs badge... will upload a picture of the rear when I manage to get the old number plate off
Looks very smart there. They are pressed metals aren't they? Love the look of those ;)
Bought my GF a Nikon D3200 for Christmas, finally got her to take a picture of the car :)
Does it more justice than the camera on my S4 lol
So good I finally changed my sig picture :)
Managed to get the rear number plate of the other night which involved having to grind the old number plate screws off...... the most pita job ever.
tried drilling the head of the screw off which resulted in glowing screw and an instantaneous fluidless blister when I decided to test if it was still hot....
but even after I got the screw head off they were then still held in place by the screw retainer thing that would not budge so had to grind the lipped part off.....
Anyway as ever it took longer than the 5 mins I told my GF it would take lol.
painted the holes to prevent rust and then just used a bolt and nut with wide washers either side to hold the number plate holder on.
Also in the picture my updated badges, kept them the same layout to our car rather than the 2013> which have octavia driver side and vrs passenger side....
Also found a SE badge apparently for skoda looks like the same style writing and probably stands for special edition..... But not in my cars case it stands for Shadows Entity lol initials of my name on here :) might be a bit marmite for some of you but I like the idea
  • 2 months later...
Well made some progress today I've sort fitted the FMIC in as much as it's on but not all plumbed in as I need a few more pipes as I'm doing it with a BAM inlet manifold and charge pipe...
bumper was easy to get off up until the last screw it seems a previous owner had hit a bump and cracked it where the screw goes and used the wrong threaded screw and a massive washer which was rusted into place so had to chop it off to free the bumper...
cleaned as I went a long as there's lots of bits that can never be cleaned until you take things apart...
whats this?
had to relocate the horns a bit to make room
This is how it was going to be but I remembered a pipe I had that is perfect for the job only problem is its Blue....
also refitted my CAI as it had been put back up high as with all the big puddles a while back
and irritatingly I forgot to take pictures of it down on the ground complete so will add them later....
whats this?
External temp sensor.
finally lol is that a massive drive or you working in the middle of the road :giggle: thought you didnt want to go bam!
in the road as my drive has a slight gradient if you Jack up on it the jack tries to move so useless drive for working on really
All put back can just see it through the grill as it's the standard one20140319_102924.jpg
widemouth plans?
