4x4 Turbo - Sleeper-ish :o)
Looks like another great thread.
  • Replies 319
  • Views 51.9k
  • Hi All, Just a quick photo of the Wagon looking guilty........... :think: Craig..
  • Hi All,   Well unfortunately the skoda did sell and went to a local VAG guy not far from me whom has already fitted Audi S3 leather and Brembo BBK......   Im going to be working away in Norway alo
  • Hi All, Well i have finished of the coilovers! and its low low low!...... The front bumper is only 2.5" of the ground which may cause problems in my area due to bloody speed humps so tomorrow night g
Hi All,
Quick update: Turbo gauge and A-pillar Pod has also arrived.
The pod will need cut to shape the pillar in the car but should be pretty easy.
Cheers Craig...
1 bar is only 14.7psi?
Im running 20/21 psi at 210bhp
Yes.... Spot the mistake ha ha :giggle:
This is why you dont order things after 4 pints of bullmers and nearly 2 bottles of red wine!... My error.
I will be ordering a 2 bar gauge right now..
Any one want a 1 bar gauge?? lol
Cheers craig..
I prefer it in psi
Mine
Gives a more accurate reading imo
Hi All,
Well Saturday i thought i would fit the coilover kit!...
I statred on the rears which took about 1hr30 each side but in the end got them fitted.
So to the fronts, only issue here was the hub bolt siezed but finally came out, Got the new strut in place let the car down and look inside the bonnet at the strut top and the ram from the new shocker was sticking through about 4" !!!! What the flip??..
I look at the other new shocker which was not fitted and striped it down to find out the top cap where the spring sits against has a hole large enough not just to let the top threaded part of the ram throught is but also the main part aswell.
The threaded part is about 14mm OD and the main ram is 20mm OD -- The top hat pieces is 20.5mm OD im guessing this has been machined wrong??
Any ideas.
Top hat piece below with a 20.5mm OD hole.
The ram with 14mm OD threaded part then has a little flat shoulder and the main ram is 20mm OD.
On this picture you can see the top hat goes over threared part and then carrys on down the main shaft thus letting the whole ram come up through!!!
I am guessing that top hat piece should only allow the threaed part pass through it and should sit on the little shoulder therefore not letting the whole ram just come up through.
Any help or advise would be great guys...
Cheers Craig...
These are all the bits in order from my KWs.
So there should be a nut that holds the bearing in place.
Hi Rob,
It looks like i have not taken the bearing off the old shock (The 3rd loose item from the right in your above picture), This will slide down and stop the ram from coming up past the top mount.
I have been racking brains all morning at work and new something was missing.
I will strip down the old shock and fit the bearing when i get in from work and fingers crossed it all work correctly.
I think sometimes when you doing the same job for a long time you get tired and dont concentrate, Thats my excuise anyways.
Cheers Craig..
Buy new top mounts.
Don't re use your old ones unless there fairly new.
and the top mount bearing is far right in the picture mate not third in.
No its not, he is right. From right there's nut, rubber, bearing.
I'd always buy new top mounts & bearings when changing suspension personally, at least then you know everything's good.
ah yes, i see, sorry that man ignore me, i wasnt looking hard enough
Hi All,
Ok so I stripped down the old shock and removed the bearing which looked new and turned smoothly etc.
Fitted it to the strut and it all slotted in perfect! So just got the drivers front to finish up! Hopefully get this done tomorrow night.
Thanks for the helps guys!
Cheers Craig.......
Following this with interest....
I have a spare gt30 suitable for the JS manifold......if you're interested????
I've had nearly 9 years of experience with Brian & Michael at Jabba, you can't fault them!!!!!!
Steve
Steve
Hi Steve,
From the information I have getting so far from JS
It will be the GT30 turbo required.
What sort of cash you after for the turbo? How many miles on it etc..
Cheers Craig....
Will pm you.
Steve
Hi All,
Well i have finished of the coilovers! and its low low low!...... The front bumper is only 2.5" of the ground which may cause problems in my area due to bloody speed humps so tomorrow night gona raise the front up a little bit.
Anyways a few pictures for you all.
Whats the verdict people??...
Cheers Craig...
I like.
^ Higher ^
You'll loose the sump like that :giggle:
^ Higher ^
Heresy!
I thought car forum rules demanded that only requests for "More Lows" can be posted?
4x4s' are there to break the rules :rock:
seriously though, low is slow
no room for suspension travel
Yeah i think im gona raise the car about 25mm and see how it goes from there.
Cheers Craig..
lower!!! i have mine about this height and its fine....maybe a couple of diagonals over speed bumps. Only issue i found is it gets bouncy!
Hi All,
Me at work hitting the speed ramps.....
I had to hit the tallest one sideways otherwise the bumper was going to catch.
Will be lifting the car up to night a wee bit.
Cheers craig...
