< Wing mirror indicator needs replacing >
^^^^^^^^^^^^ as above. Operation is by design.
Hi my passenger side has gone on my 2008 vrs, have replaced the led unit but still no light. Does anybody know if there is a fuse to check.... Thanks
Edited by bell222
Anybody please, have no idea what is going on thanks
Have a look on VCDS owners map, see if there's anyone local. As with most faults, a scan is a great place to start.
If you can't find anyone, I have VCDS and will be in Spalding around Easter time. (I'm not on the owners map though)
Edited by RainbowFire
You can easily check to see if the loom wire is putting power through with a multimeter.
  • 2 months later...
I thought I would tag this on to this post...as it worked brilliantly for me:
Its a guy called Narcis and shows how you can do this mirror indicator change without removing the mirror glass which can be fiddly having had experience.
Read my additions below before you do it and it might help you do it.
https://www.youtube.com/watch?v=KUenlCzYPdY
Additions
1) I used an old credit card/store card worked perfect for getting at the rear edge clips (side at bonnet end)  to remove the cowel casing..
2)KEEP the mirror glass parallel with front mirror edge when taking cowel off.
3) Slide card in the rear til you feel the clips, then use nails to separate it 3 or 4mm...next, the secret is to pull the cowel out and away from where it joins the mirror bracket near the window carefully pulling it away, lifting it at the back and twisting it over the mirror glass carefully- TAKE YOUR TIME....you don't want to be forking out for a mirror.
2) You need a thin torx screwdriver, I think its 3 or 4mm across if I remember
3) Unlike the video, Use the electrics to move the mirror to get to Screw 2 - Dont remove screw 2 from its hole - you dont need to.
4) Check the screw holes on the new part are the same as the oem part, mine were a little tight, so be aware...
Anyway Hope that helps, It is a good solution and Quick!
Edited by Blanes
  • 2 months later...
Hi,
Have an 09 VRS and had MOT last night, fella flagged up the drivers wing mirror indicator wasn't working but this wasn't a failure.  On reading these posts I see mention of a puddle lamp.  without sounding totally stupid how do I know if mine has a puddle lamp or not?
thanks
I believe that when you open the door it shines down onto the floor from the mirror to show you the puddle your about to step in.
I don't have them, I just get wet shoes and know it must have been a puddle i stepped in.
I do have the very chav laser door lights which shine a nice Skoda logo onto the floor for me.
Edited by andy-fisher
is this a p**s take?
No, it wasn't meant to be. It is a light in the mirror which illuminates the floor when you open the door. Mine only has the indicator in the mirror where some have a combined indicator repeater and puddle light.
c7278384-f589-4d9c-8607-855616768d671712
I have laser projectors in the door cards which light up the floor with a Skoda logo.
apologies, just sounded like one of those dodgy sort of comments,  thanks for the response.  mine definitely doesn't have those.  My mirror is similar to that in the picture with just the little clear slit lense.   I assume this is the part I need?
http://www.ebay.co.uk/itm/381518045878?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
I can't get on ebay on works computer (blocked site) but I'm sure someone will be able to confirm.
