JoshH's Fabia VRS
Passed! No advisories! It's brought me a whole world of hastle Jake but it's all fun and games mate :)
  • Replies 319
  • Views 31.7k
Passed? Did the tester have a white stick and a guide dog....
Not quite, logged into the pc, made a brew signed the sheet and updated database :)
Picking up full seat sport forge pipe work tomorrow - it was originally mine from my seat sport forge kit I had on the Ibiza.
It's a better kit than the stand alone pipes they supply in the skint kit.
Be ordering a ths fmic and piper decat in a week or two as well.
Oh and a clutch... Unsure which right now
Loba lightweight flywheel - 6.8kg!!
Ordered along with
Sachs sre organic clutch disc and pressure plate rated to 390ft/lbs
PM me how much that set you back Josh, I'm thinking about stuff right now ;)
Edited by DanHam
Josh me old fruit lol could you PM me also on info for the above clutch, my DMF is starting to not like life methinks. Sorry for clogging your thread up. I'm going to Coombe so hopefully bump into you put a face to the name so to speak.
Sent mate!
Pm me about the cool and where you got it please bud!
- fit hr rarb
- fit fmic pray for no boost leaks
- order fmic brackets and bolts
- order oil and filter and new drain plug/washer
- order gearbox oil
- fit decat
- order new exhaust gasket
- fit smf and clutch
- sort insane torque steer, wind front coilovers up a few turns?
Clutch arrived today, waiting on fmic rarb and other bits before it gets done in one!
Got quite a bit to do then. Hope you get it all done in time. I'll need to do a service before Combe and hopefully my carbon fibre goodies will be ready too
Will have that lot done in one day..that's the plan at least lol!!
Be good now just gotta hope the weather isn'tkle last April!
I missed last April. I hear it was a little soggy lol
Couple of goodies arrives at work today :D
That rarb looks very chunky, are the whitelines thinner? Think i may have to invest in a rarb.
That bar is 25mm Joe it's huge! Seriously stiff too mate! Can't wait to get it fitted :)
White lines are way thinner, as is the Jabbasport one.
Get one dude, I needed the stiffest I could find as I have a 22mm bar up front.
Is 22mm uprated on the front?
Yeah white lines adjustable one mate
Nice. What rarb is that?
H&R mate
Looks cool, never seen them before. Bet it will make a huge difference :)
Hmm...from past experience...be prepared for the lunching of your front tires if you drive swiftly with a H&R bar.
As a side note I've also experienced tyre eating from an eibach front arb, but then again my driving style was not appropriate in the least.
It's not a negative, just as long as you are aware, and keep an eye on the inside of your tyres. ;)
Yeah expecting increased wear mate. I have an appetite for tyres anyway it seems, these Hankooks have a pretty soft sidewall too.
I think next plan is a mod not done very often, whiteline rear toe in reduction shims, should get the back end a bit more lively :) will double check current rear toe in to be sure I've enough to play with but I suspect so.
Be aware that high speed straight line stability is one of the trade offs of toeing out the rear end, as apposed to the "lively" feeling you wish to achieve.
Stupidly I once toed the front wheels out after too much internet reading. Damn the turn in and direction change was amazing, like a razor. Unfortunately the inner front tyre wear rate doubled, and also promoted some rather serious rear end action when lifting off.
It's all down to personal taste at the end of the day anyway, so experiment to find out what settings suit your driving style. :thumbup:
