Hub nut thing
Hi there
Could someone tell me what tool is needed to remove the funny hex nut on the front hub of a mk1 Fabia please?
I need to take it off to replace a grenaded cv joint.
Ta
just a standard socket -35mm? i think
Edited by Lofty79
This is the piece, so where do you get a 35mm allen key from?
Edited by Groundbreaker
allen key? Have i got the right part?
Uploaded a photo to the previous post now, sorry it didn't work first time...
ah right now thats different. when ive had these before ive had to find a bolt with a head that fits tight in there and weld it into a spare socket.
Cant seem to find specific tool for sale mate sorry
Ah right, I'll have to get rummaging through the spares box for a random giant bolt then.
Thanks for the reply at least I'll stop Googling for a 35mm hex key now. ;)
yeah sorry mines just a nut, i assumed the same with yours
If only, this Fabia's a 2000 model so it looks like they changed it to a proper nut at some point...
According to Haynes the early fabias had this style of nut, later ones changed to a funny hex style shape on the outside where you could use a large socket
Does it give any ideas as to how to remove it?
I've got a proper tool to remove them, i can find out the size tomorrow if noone els knows before then.
Yes please!
36mm multi hex socket
No, I've got the early model without a normal hub nut.
Look for a large hex key built into a socket......like these.........which are listed up to 19mm across!
http://www.toolbuddy.co.uk/individual-hex-allen-170-c.asp
......then for the replacement hub nut which is the a different shape you need a socket......but it has to be a set size and number of sides........I think it's a 16 sided socket...
I will look at mine tools when I get home tonight..........and post the spec of the socket up for the new hub nuts.....
Edited by fabdavrav
For the new style hub nut you need a 36mm 12 point (round style socket).
