FL and maxidot sorted
I think it should be ok, although the donor pod may need to be decoded.
where are you located?
Hi Eddie,, I`m in clacton, but i have a customer in southwold which i visit, so depending on how long the job would take a could pop over to you..
Clusters changed today on JJ120979 car
A 2008 vRS TDi Estate
Original Cluster
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No SW: 1Z0 920 912 E HW: 1Z0 920 912 E
Component: KOMBIINSTRUMENT VD1 1610
Revision: V1610056 Serial number: SKZ7Z0H4743424
Coding: 0003401
Shop #: WSC 22038 210 91843
VCID: 37770CA346AE64A0D06
No fault code found.
upgraded to
Part No SW: 1Z0 920 942 E HW: 1Z0 920 942 E
Component: KOMBIINSTRUMENT VD1 1612
Revision: V1612036 Serial number: SKZ7Z0H4743424
Coding: 0003401
Shop #: WSC 00152 210 91233
VCID: 3A71159775BC79C82F8
Tried a new Scirocco Colour version
biggest problem now is the shape of the Circuit board is different to the Octavia
and you will also get the message "Welcome to Volkswagen"
this is a good sign that its working! I don't mind the VW boot screen.
  • 6 months later...
Just had a maxidot retrofitted and had to go that route as, although it was a brand new cluster, the immobiliser refused to accept it
Hi Al. How much did retrofit cost and where in uk did you get it done? Just put a deposit down for new Monte Carlo diesel, but no maxidot, and local skods dealer says they cannot do retrofit. Any advice most appreciated. Regards, Steve
Hi Eddie. Been reading your retrofit posts with much interest.. I have just put down a deposit on a new Monte Carlo Tech diesel, Comes with satnav and bluetooth, but no maxidot, only ordinary trip computer. Cannot add any extras to the car, and local Skoda dealer says they cannot do retrofit. Looking for any advice. Really taken with maxidot..but should I forget about it? Regards, Steve
