The Czech Devil - HYBRID TURBO
April fools bitchez
  • Replies 243
  • Views 28.9k
  • BIG UPDATES   Oh Hai!         and the "barely" used clutch
  • Funds are through!   £5000 to spend on the Octavia!
  • Everythings bolted up to the replacement engine, just awaiting some bits then ill be putting the new heart back in! Ill upload some pictures at somepoint
not even funny man :@
Sorry Terkz! Your the master of Octavia project fooling!
:whew:
I am slightly disappointed as i would have had some potential bargains on my hands if you did strip it.... Whats the latest with it?
UPDATES!
SFS k300 TIP
Though im missing the PVC hole.... Spoke to BBT and he said he's removed them... How would i run my catch can now without venting to atmosphere???
This is the plastic elbow from the oil cooler.
Id recommend to anyone, clean it!
My BBT K300 all built up.
Engine all rebuilt
G60 SMF + VR6 clutch to go on
Tehehehehehe
put the catch can in the dv hole and run no dv for mad chu chu :giggle: :giggle: :giggle:
nice nice nice :rock:
Thanks man.
That idea is a bad idea....I could tap it into the returning intercooler pipe, but for the hassle just for emissions im just going to vent it down the wing.
bad idea? its a brilliant idea :yes:  i did that right back at the beginning and got shot down for it bad running and leaking boost
ok new idea! send that back and get one with it on :rock:
Venting the gases isnt going to affect anything! Unless these engine like exhaust gases that is.
Stick a filter on the end of the silicone pipe and throw it down the wing. JOB DONE....Might kill a few squirrels but otherwise nae bother
How would it leak boost? its not even attached to anything with boost, only crank case pressure
How would it leak boost? its not even attached to anything with boost, only crank case pressure.
that was exactly my thinking
http://www.briskoda.net/forums/topic/262521-terkins-vrs/
i never actually noticed any difference when i did it :giggle: :giggle:
when i had smoke test it came out of the lower breather iirc you have to vent that aswell remember. i cant actually remember as its in the bulk erase now :giggle:
Ill have a catch can.
Top and lower breathers T pieced into catch can and then the hose that would normally run to the PVC would be atmos.
Engines bolted up.
Things needed to do:
Bottom gearbox mount
Shafts
Wiring
Waterlines
Intercooler to fit
COming on now!
Installed!
How it looked
How it looks now
Might need this
She's all wired up and it cranks over fine with no errors on the dash.
Need to install my intercooler then prime the turbo
Then
I SHALL START IT :rofl:  :rock:  :sweat:
Nice job mate. Done similar with my tt last week :)
Seems to be alot of wires on that second pic lol
That's because there is a fair few wires on the Octavia, plus in wiring in my oil pressure gauge
Intercooler is being installed today.
Oil, water being ran through it for a while for leaks.
  • 3 months later...
Going to try crack on and finish this this week.
Been out of work for a while so iv had no cash to play with but all has changed now so its on the go ahead again!
Keep you're eyes glued!
was wondering what had happened to this!
Same here
