Help me find my whistle!
Have already posted this in Fabia mk1 section but hopefully someone can help me on here?!
For the past year I have had a frustrating WHOOSH/Whistle on boost from about 3rd gear of full throttle through the gears.
Removed EGR:
Eliminated possible "whoosh" through EGR pipe
I have checked for boost leaks:
Found 1 leak after pressure test: light hissing on joint (bottom pipe, one tooth worn on coupler?)
I bodged this with sealant and for approx 3 days..
Test drove and car felt lively, went well through the gears without a whistle/very faint whoosh for at least 100 miles
3 days later, whoosh returns/less power: (thought sealant could have dispersed/worn away?)
On inspection boost pipe hanging loose:
Replaced bottom boost pipe with second hand one..
Drove ~5 miles: Whoosh returns/less power
Replaced coupler on bottom boost pipe, fits sound with fresh seals.
Drove ~3 miles: Whoosh/No change/less power
On Inspection boost pipe fitting fine, snug in intercooler joint
Boost test:
No leaks
Tested TWO other Fabia's:
105k BLT Engine 2006: Faint whistle on boost (similar to when I bodged joint with sealant)..lots of power
67k BLT Engine 2007: No whistle on boost, Lots of power
Ok people...what's going on?!!
