Ignition Switch
Hi Guys
Looking for the part number for an ignition switch
Has been flaky for a while but getting worse lately, when i turn the car off it behaves like the key is removed
Doors unlock, radio off etc.
Are they easy to change?
Dallan
Youll need a new key blade as well. As im not sure if skoda can match your barrel combination.
Hi Matty
Not looking to change the key, just the switch unit at the end of the lock barrell
Oh rate. Sorry for that haha.
They are a PITA to change
removing the transponder reader and key barrel is easy enough.
There are 2x sheerhead bolts that need to be removed
All sorted now, thanks to Eddie-NL for the info
Dallan
Just for others
I thought the whole Steering Lock and ignition switch was all one part
Ignition Switch part number 1K0 905 865A
After some investigation the actual switch can be changed without having to change the steering lock with the sheerhead bolts
To remove
prise the plastic cover off and you will see 2x tabs which can be released with 2x small screwdrivers and pull it out
The main reason for changing would be due to strange behaviour with the door locks, interior lights, radio staying on etc
Common faults that show up with a faulty one
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 BF HW: 1K0 953 549 BF
Component: J0527 051 0101
Coding: 0000011
Shop #: WSC 00066 000 00000
VCID: 77F7CCA3062EA4A010F
4 Faults Found:
00576 - Terminal 15
012 - Electrical Fault in Circuit
00883 - Ignition Switch (D) Terminal S
00884 - Ignition Switch (D) Terminal X
01744 - Ignition Switch Terminal P (D)
Modified switch, was a very common fault at one point. And like you say it just pops off the back of the steering lock.
Hi All
New switch arrived today, thanks to Eddie-NL and fitted in 10-15 mins including disconnecting battery and resetting the time after :p
Dealer reckoned 90 mins :rofl: :rofl:
Anyway i now have 1K0 905 865A (Revision A) replacing the original 1K0 905 865
Pity the dealer who scanned it at 12 months old in 2010 didn't seem to know that even though it was logging faults :think:
Anyway enough bitchin, thanks for the good advice as usual now i can listen to the radio and not have to leave the car running
How much was the switch? mine is doing the same as yours & my central locking unlocks & locks as i drive along sometimes,was it easy to fit?
Bought from Eddie-NL for a reasonable amount :) not sure if he has any more, dealer wanted nearly €40, i have also seen them on ebay
Dead easy to fit, remove trim
unclip the outside cover
and there are 2 plastic tabs holding the unit in the end of the metal barrell
unclip connector, and refit in reverse, just make sure the slot in the middle lines up correctly
instructions here
http://skoda.workshop-manuals.com/octavia-mk2/index.php?id=3112
when you reconnect the battery, you will have some lights on the dash, its normal just go for a quick drive and they go out
Thanks for that,he has been in touch about a switch,i wont disconnect the battery,if the ignition is turned off & the key out im sure it will be fine.
Yeah but you need to turn the wheel to get at the trim screws so key in to prevent steering lock :)
Just for others
To remove
Coding: 0000011
4 Faults Found:
00576 - Terminal 15
Hi Eddie,
Is it the same part no. for a 2006MY PD140?
Andy
Sent from my HTC One X using Tapatalk 2
Are you seriously telling me that the switch is a 10 minute job to swap without needing to remove the barrel itself?
Our car has now been at the dealers for over 5 weeks. They found a problem with the switch so ordered a new one.
While fitting the switch a pin (they said) came out of the barrel and they were unable to fix it. Still waiting for the barrel to arrive.
They have also removed every bit of trim from around the steering wheel, the steering wheel itself and (I think) the dash clocks.
If this is the case I will not be happy! :wonder:
Phil
Ah DM Keith, you gotta love 'em.
I wouldn't trust them to top up the washer fluid.
I replaced my ignition switch tonight,it took me 15 mins,worse part was finding a screwdriver small enough to release the switch,it seems to have fixed my problem,phil all i can think of is the numpty's at dm kieth have been rough getting the switch out & broke the casing hence you needing a complete ignition switch,lock etc.
Phil, its what mikey said a 15 min job, i used 2 watch screwdriver's to unlock the 2 tabs(shown below) 1 is the switch, 2 is the wiring connector, arrows show locking tabs
i cant see how they could damage the barrell it seemed fairly sturdy metal to me
There is only the flat shaft which sits in the middle of the actual switch which goes anywhere near it
Edited by Dallan
Yep, just done mine in 15 minutes as well.
Got the new switch from TPS today but the part number has been superseded by 1K0 905 849 B which seems to work fine but comes complete with a short section of wiring loom that I didn't appear to need.
Cured the starter motor kicking in with the key in position II !
Luckily I ran accross this topic 2 days ago as my car was scheduled for 105kkm regular service today. It had all the mentioned symptoms (radio off, internal light erratic behaviour, automatic window opening). I was afraid that something more serious was going on. Today the switch was replaced with the latest 1K0 905 849 B revision and all the functionality is back again.
Efficient fix for a small amount of money. Really happy. :whew:
Car is back.
New switch and everything is working fine.
Phil
New switch has fixed both my problems too.......best £15 ive spent. :thumbup:
  • 8 months later...
i think ive got the same problem :sweat:
get it scanned first, to confirm that it is the same issue
I have one switch remaining if required
  • 3 months later...
instructions here
http://skoda.worksho...dex.php?id=3112
looks very useful, except the clickable links in the document don't respond.
Anyone had the same problem, or got a solution ?.
Thanks :D
