What should I keep in my car?
Hi, I've only recently got to actually own a car, so I'm curious about what stuff I should have there.
I now have: Tow rope, jump cables, ice scraper with a brush, squeegee, maps, blanket, umbrella, torch, couple of coins, cleaning rag, napkins, garden gloves, a bottle of water, and of course the mandatory stuff (vest, fuses, bulbs, first aid kit, the triangle).
I'm considering: 1kg fire extinguisher, windscreen washer liquid, 4 other vests for passengers, a proper sleeping bag (winter only), a cheap cell phone with long battery life + charger, a couple of spark plugs + spanner.
What else do you keep in your vehicle, or what you'd recommend me to have?
  • Replies 64
  • Views 4.5k
  • A few decent CD's for when the radio is a bit naff Regards all Juan Sent from my iPhone using my thumbs
  • A dirty blonde on the passenger seat would be nice Regards all Juan Sent from my iPhone using my thumbs
  • Auric Goldfinger
    Auric Goldfinger
    A blow up Doll to entertain yourself whilst under the blanket for an hour.
I can honestly say I have non of that, but then in the UK non is obligatory under law. When driving abroad I will have the bare minimum, bulbs, spare glasses, high vis vest, emergency triangle and 1st aid kit, and usually some glass cleaner and a mf cloth.
Regards all
Juan
Always carry a Flask with boiling water incase you ever have to give a pregnant woman a lift to the maternity ward but get delayed before getting there, and the baby will not wait..
you can then have a nice cuppa while the Paramedics deliver the baby.
george
I think you may have OCD?
I keep nothing like that! I have the RAC for any events!
I have a ice scraper & fuses. I suspect it depends on firstly what is mandatory in your country and secondly what kinda trips you make. I drive to work which is 15 min away, so I doubt I'd ever be forced to sleep in my car overnight.
I make 200 mile trips once in about 6 weeks, so that's a bit of a different use case, yes.
Long weights and sky hooks would also be needed.
On a more serious note I think you may just may have everything covered lol
Regards all
Juan
I have a bottle of alloy wheel cleaner in my boot? Not sure why........at least if I get stranded I can clean my wheels! Actually scrap that I haven't got an alloy wheel brush in my boot..........I'm stuffed!
On a serious note......you have got 99 pc of natural disaster resources covered!
Got a better one - a dirty brunette :) .
That was the plan. Thanks :) .
Edited by sheldon_cz
This thread is now useless without pictures.
I'm not going to showcase my girlfriend, it's enough I showcased my car :wonder: :rofl: .
I keep a pair of sunglasses, phone cradle, spare phone lead, small bottle of water, torch, bulbs, a few pieces of rag, oil (typical 1.4 16v!), screw driver set and some tape. Anything I can't fix with that lot is an RAC job.
In winter I also keep a snow brush, ice scraper, gloves and warm coat in the car... I may have a Gregs steak bake in there somewhere too!
May lol !
Jesus that's a lot of stuff!
I have bulbs, fuses and a staff emergency card :thumbup:
I'd have bought a Van :think:
A big bloody van !
Things to carry in car
Owner’s manual This should naturally be in your glove compartment anyway, but you want to make sure that it is indeed in your car. The owner’s manual provides a ton of useful information that can get you back on the road, such as detailed images of how to change a tire and so forth.
Old cellular phone, powered off, with a fully charged battery An old cellular phone, even without subscription, can be powered on to call 911 or 999.
Blankets Even if the weather is nice, you could wind up having to spend several night-time hours in your car. A blanket makes it possible for you to curl up, keep warm, and sleep.
Battery-powered radio (and extra batteries) If weather conditions are atrocious, a battery-powered radio (or, even better, a crank-powered one) can provide you with basic information about what to do.
Bottled water This is necessary for sustenance if you get stuck somewhere and have to wait for a while.
High energy snacks and/or MREs Similar logic to the water; high-energy foods are essential. I usually keep some nuts and some jerky. I know of at least one person who would not go on any trip without a couple MRE (meals ready to eat) in the car – you just pour some water in the pouch and they self-warm and are ready to eat.
Maps Keep a detailed map of the state you’re in in your car at all times – or even a current atlas if you have room. Don’t completely rely on a GPS navigation system.
Booster (jumper) cables These can enable you to get your car started with a dead battery (if a good Samaritan comes along) and also enables you to help someone out in a fix.
First aid kit (and manual) This can be vital if you’re in an accident and someone has injuries. Slowing down bleeding quickly can mean the difference between walking something off and going into shock.
Fix-a-flat If your tire has a pretty rapid leak, Fix-a-flat can often provide just enough to get you to a repair station. I recommend at least two cans.
Tire repair kit If the tire has deflated rapidly, a tire repair kit makes it possible for you to patch up the tire well enough for a short period.
Tire air gauge This one isn’t so vital for emergencies, but is absolutely essential for preventive maintenance – keeping your tires fully inflated not only improves gas mileage, but reduces the risk of tire explosions.
Road flares These are invaluable at night so that others can see you if you need to change a tire or such things.
Flashlight (and extra batteries) Similarly, a flashlight is utterly essential at night if you need to change a tire.
WD-40 This can help loosen any bolts that won’t come loose. WD-40 has saved me in a pinch several times.
Fire extinguisher (5 lb.) If you’re in an accident (or even if you’re not) and there’s a small fire, a fire extinguisher can stop something that could turn into a true disaster.
Portable battery charger A few of the items on this list require batteries. A portable battery charger can plug into your car and charge up these batteries if they’re all DOA.
A change of clothes These are incredibly, incredibly valuable in one situation: changing a tire in the snow or in the rain. You’re going to get soaked either way and sitting there in wet clothes is not a good option.
Towels Towels have a lot of general usage: helping to keep warm in the night, drying off after getting drenched, and aiding in pulling out of mud, ice, or snow (put them under the tire for traction).
Duct tape I’ve reattached a muffler (temporarily) with duct tape before; since then, I keep a roll around to help keep me on the road.
A carpet remnant If you’ve ever been stuck in mud, snow, or ice, a carpet remnant is the best way to help get yourself out. Wedge it as best you can underneath one of the driving tires, then move in the direction of the carpet. It’s gotten me out of a few sticky wickets in the past. Even better – it can simultaneously serve as a trunk liner.
“Emergency money” A small amount of money in change and small bills can be invaluable for tipping tow truck people or all kinds of other situations that are easy to imagine.
Road salt (in winter) can rescue you if you’re stuck in ice. Dump a lot of it near the ice, get in the car under the blanket, and wait for an hour. Then put the carpet under the tire (as described above) and a lot of the time you’ll pull right out.
A shovel (in winter) is invaluable if you ever face a giant snowdrift. I’ve been saved by having a shovel in the back of my truck in the last month; I can’t even count the number of times it’s rescued me in the last year.
Hat, scarf, and gloves (in winter) can help keep you from being frostbitten if the weather is bitterly cold. Keep them in multiples if you have passengers.
If you have all of these items in your vehicle (and they don’t take up as much space as you might think), you’re well-prepared to manage many roadside situations. With just this little bit of fix-it-and-forget-it preparation, you can save yourself a huge amount of time, prevent yourself from freezing, and save a ton of money if an emergency befalls you. If you’re mechanically inclined, you might also want to include some more tools in the trunk, such as a socket set and wrenches, but if you have no idea what you would be doing with them, they’re not necessary.
Flat head, phillips, 13mm spanner and electrical cleaner spray. Not much you can't sort on VAG with that.
Or a trailer!
Whatever is compulsary to have in your car in your country, i'd just stick to that.
Sounds like you would be prepared for an all out Nuclear War :giggle:
A spare wheel, jack and wheelbrace.
My old Ford has a bit of a reputation for the clutch cable adjuster going and they're not too nice to fit. My cunning plan is to carry an adjuster kit and an AA card.
My jacket and a box of chewing gum. Nothing else at all!
A box of orange buff sparks.
