Engine fault code help please
I replaced the MAF and then the vcds came as this. Anyone any ideas please?
1 Fault Found:
000256 - Mass Air Flow Sensor (G70)
               P0100 - 000 - Supply Voltage - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 0
                    Fault Frequency: 1
                    Mileage: 1048575 km
                    Time Indication: 0
                    Date: 2111.15.31
                    Time: 31:63:63
             Freeze Frame:
                    RPM: 1124 /min
                    Load: 20.8 %
                    Speed: 0.0 km/h
                    Temperature: 58.0°C
                    Temperature: 50.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 11.557 V
Readiness: 0000 0000
Check the plug is fully seated, clear the fault and see if it comes back.
Sent from my Nexus 4 using Tapatalk 4
Thanks, I have taken it off and on a few times and no change. Can you buy just the adaptor and then put the cables into that? Thanks for your help much appreciated.
Fuses ok?
Hmm not looked, do you know which fuse serves this?
Not off hand. But you have a voltage fault at the air mass meter, i'd say its likely and I know there is a fuse for them.
Tried the god old off and ram in as hard as I could and re scanned and gone :)
Thanks gents at last fixed and drives like a dream once more. My wife said she could not notice the problem lol. She can't drive it fast though. Will replace PCV as after taking it off and cleaning vapour is fine but this was crazy amounts.
Just after the warranty expires sods law oh well sorted.
You didn't give the engine, but it's usually on fuse 29.
Its a 2.0 tsi so may replace this to be sure. Thanks
Yes, it's fuse 29. The MAF plug needs to be wiggled on a bit more - even after the latch clicks home.
I wiggled :), thanks
