Retrofiting factory options
Does anyone know if it's possible to retrofit some options only with the use of vcds coding?
The ones i would like mostly to know are:
- driving selection mode,
- driving activity assistant,
- crew protection,
- lane assist.
Thought drive mode was standard on all the octy 3 models?
SE and above. Outside the UK its an option even on the vRS
Deive mode its an option in Portugal but i think its possible to enable with vcds. Does anyone know how?
Ahhh ok sorry didnt spot you werent in the uk and forgot it isnt on the S!
No problem.
I really want to set the driving profile mode
You won't be able to do it just only VCDS as you need the button on the centre console.....
I think You can do it via Bolero/Amundsen/Columbus as well.
I can't on mine, I have to press the mode button to get the options.
Can anyone confirm that the button is needed or if we can access directly by the radio unit?
There is no access on my vRS to driving mode without pressing the driving mode button infront of the gear stick.  There nothing on the infotainment to allow access to it.
Thanks for your help.
Does your passenger mirror fold automaticly with the reverse engaged or only with the automatic seats?
How do you set the position?
My VRS wagon arrived without the Driving mode button, it was supposed to be standard on NZ VRS's but got left off by the factory.
Skoda NZ say they have ordered a Driving Mode button and will fit it as well as loading the required software. Hopefully it will be sorted in the New Year.
I doubt thats only the button and the software thats needed can you please check with tour dealer?
The only thing out of your list you can enable without fitting extra parts is the driving activity assistant. That is assuming you have the correct steering controller fitted. Odd, as most people turn it off from the menu on the MIB unit, if it is what I think it is and warns you when you are tired by monitoring your steering input.
All the other bits will require extra hardware.
Sent from my phone so please excuse brevity and spelling
and wath about the passenger mirror turning down when you select reverse? thats only possible withe de automatic seat?
Nope, it can be enabled but there is no memory function, so it dips a fixed amount
my passenger mirror don't fold on reverse, does anyone know how to set it step by spet? My dealer told me that it wont work. Isn't he wrong? i have the elegance version without memory seats.
Edited by Adrgolfv
Only with vcds?
Yep
Come on proper retro fits not ur Vcds lol Folding mirrors on a vRS, come on who will be first lol
We avaliate our needs individualy, i think a forum is about that, not only for those who bougt a car and want an airplane.
Edited by Adrgolfv
Does anyone know how to activate the side mirrors to fold out when we unlock the car? Mine only do that when i put the key in the ignition.
