Bluetooth Unit
What phone do you have?
  • Replies 119
  • Views 13.2k
  • It will work but it is older and limited in its functionality - you won't get the phonebook on the Columbus for example and will therefore need maxidot (see http://www.myturbodiesel.com/1000q/a5/VW-bl
Galaxy Note 2
It should work in both modes, hfp and rsap... just so you know a2dp is bluetooth streaming, not a phone pairing method.
Sorry I didnt read your original mesaage properly. Voice control depends on the head unit, do you have a Columbus? I'm not sure the Bolero does voice control.
I noticed with this module you pair a music player separately so have you done that?
I also had trouble with the internet. If you dont have WIFI in the maxidot menu you need to code the last two bytes as 0101.
And the choice of connection is in phone mode in the menu. It will connect in rSap by default if the phone supports it.
Adam
I have a bolero. I'm not too bothered about voice control, just wondered how it worked!
I'll try pairing the phone as a music player too.
What's the difference between the two modes?
Thanks for your help Adam.
Rsap is remote sim access protocol and takes over the sim so the car becomes the handset, offering the full functionality on the head unit and maxidot and better reception. The phone is mainly disabled. Hfp or hands free protocol retains the phone control of the sim and just the calling and phone book is read by the bt unit.
Rsap is only available on some phones, most notably iphones dont allow it.
Voice control works by pressing a button on the steering wheel or the head unit and you just have a few stock commands. I find that it works ok but its a bit of a gimic in my opinion.
Got the BT audio working now.
Next question, it the setting menu there's 'data'. When you select this it asks for an access point. What does this do?
The wifi works by tethering to your phone and using your data. Any handset in the car can then connect to the wifi, including your own allowing digital radio connection for example.
To do this you need to create an access point for the module which is the standard access point your phone already uses to connect to the 3G/4G signal. I googled the details for o2 in my case.
Do you see wifi in the menu?
No I don't think I have wifi. It's not in the menu and my module is only the C one, don't think this has wifi.
Ah ok, I thought you had the D unit, and forgot you mentioned the C unit earlier!  The C unit doesn't have WiFi as you say but then not sure why you would have the data option in the menu...
Adam
Guess I could try putting in the access point and see what happens. I'm on Vodafone, any ideas what it will be?
Isn't it possible to have a data connection without having a D module. There are instructions in the manual but they are very vague.
Before I got my D module I used to use an Android app called BlueVPN which worked quite well
How did that work then ashfan?
its been a while now but BlueVPN is a free app from the Play store. After installation you just run it and from what I can remember it finds a Skoda connection just likes the wireless D module and just connects to the internet. It was a bit hit and miss but the developer was very helpful.
I would have to re-install it and turn off wifi to remember how it works but if I can do it anybody can
Like I said the instructions in the manual are very vague for doing it without BlueVPN. I and somebody else on the forum couldn`t work it out.
Ah ok.  It sounds like both C and D units can do a data connection but D explicitly creates a wifi hotspot for other users (without the need for such an app).
Adam
Adam
I did it with my A unit and BlueVPN
Ok, sounds like A B and C are quite similar then.
Adam
Won't altering the coding as above allow me to access the Internet on my phone?
Thats for the wifi hotspot which yrs doesn't have. Seems like you will need an app like ashfan used with the data connection, or possibly connect in non premium mode, so you still have control of the phone handset?
Ah ok.
I'll try connecting in hands free mode tomorrow and see if that works.
Yup Internet works in hands free mode.
  • 4 weeks later...
Just been and got an 3C8 035 730. Module pairs with phone fine and shows on Columbus but still getting 'RSAP deactivated' message on phone
Sent from my GT-I9000 using Tapatalk 2
Just tried my gf's Vodafone sim card and still the same happens
Sent from my GT-I9305 using Tapatalk
Sorry to tell you this but these units are not designed to work with pre fl cars. Mine does but only courtesy of a special gateway adaptor box. Technically they can be made to work without the box, but they need the unit to be hooked up to maxidot in an FL car, and then paired up by accepting the pairing at the module end as well as at the phone end.
