Columbus code
Hello
I have just bought a used skoda yeti which has a Columbus sat nav. Unfortunately I have no code. When I turn it on, after the splay screen it says I have 2 chances left to enter code. The 0-9 function keys are green however when I press them nothing happen. The "OK" &"back" function keys are greyed out.
Any help would be grateful
Head to a dealer they should be able to do it for you,
How long have you left it waiting for the code?
If it is already coded to the car then a minute or three may be needed for it to acquire the code again.
If not, a trip to the dealer with £25 should get you the code (if the Columbus was factory fitted and/or genuine).
you can also buy the code off ebay too, around £10 and takes a couple of hours to arrive. You will only need to email the serial number of the unit to the ebayer found at the back of the unit
This won't work if the code has been changed
If the OP has no luck, I have a tool that can make a code
