How do i change the S breather pipe?.. Help!
Hi,
Need to change the S breather on my octy, changed the Y breather last week end took it round the block and the S gave up lucky ive got a silicone one to go on.. but anyways..
took all the covers off had a look and there not a lot of space to get it in there with, is there a how to guide or can any one give me a little more info on how to change it..
Hopefully can find something soon hoping to sort it today..
Just yank off inlet and pull out of bottom pipe...
If you take off the bottom breather that the s one is attached to and the y piece then pull s pipe off inlet manifold, shouldn't need to get the clip off they can be pulled off and pushed on with a bit of force.
I had to cut the clip that holds the s to the lower breather pipe though to get it off
Swear at it... Alot
sorted guys :)
Swore at it.. cursed it.. fought with it and it come off :)
just need to get a jubilee for the L shaped joint tonight and then were all good to go :) Gave them all a good clean to so should run smoother..
:D
