Changing Felicia / Favorit Gearbox Oil + changing gear selector shaft oil seal. Includes how to check gearbox oil level.
If your car has air con you will need to undo the speedo drive from under car as air con heater box covers your easy access to this and you need to add some hose on the end off a funnel to fill gear box back up... bet theres not many around with air con...
  • 3 years later...
what if the "drive gear" had fallen in de gearbox? This might be the case I came in. Greetings, jawi
You have to remove the gearbox.
problem already solved
but thanks for the tip
  • 4 months later...
the allenscrew in the centre left of the toppicture , what use does this have?
I can't find anything about in Haynes
Edited by jawi
That is a screw that holds a very important part inside gearbox. It is the part that springs back the gear shifter to neutral position.
okidoki, thanks, I will stay away from it
Hi AlI
I have just done the shifter shaft seal on my 94 Favorit but I am having huge trouble getting the new spring pin in. Any tips or suggestions.  Just can't seem to align, hold the pin and hit hard enough with the hammer all at same time
Cheers
  • 3 years later...
My gear selector shaft seal has started to leak again. So that's about 40,000 miles / 8 years that it has lasted, and that is with the protective gaiter.
Also this might be a bit late for wesacosa, but a pair of waterpump / alligator pliers can help getting the pin in.
