vrs Replacing rear brake disc dirt plates
Can anyone tell me if this is an easy enough job? 1 has come loose so thought I'd replace the both rears before it starts coming in contact with anything.
Happy enough if it's a case of removing caliper, carrier and disc but anything more technical and I would it done at a garage!
Also, be great if someone knew the part number for these (rear left and right) for a 2007 VRS 2.0TDI
Thanks in advance
Removing the discs can be a difficult DIY . The carrier is held on by two M14 Spline head bolts that are torqued to 90nm + 90 degrees.
Edited by 07 vRS Taxi
It's a hub off job on the back. I've had both rear hubs changed in the last year for ESP issues and had the guards done at the same time.
Cheers...will get the garage to do it then!! In next week for Service and Timing belt so may as well throw some more cash at them!!
  • 4 weeks later...
I need to replace both my rear back plates soon,are they a dealer part only?
Link above ^^^^^ has them. Dealer is about £20 a side.
