Fabia mk1 1.8T RWD
Ah good point :)
  • Replies 675
  • Views 85.9k
  • Slight progress. Don't have the time I used too as after over a years court case I finally have my little lad living with me, some of you that know me personally will already know. Despite lack of tim
  • and the brace is finally painted and on
  • This is a great project for sure  I am having to buck my ideas up a little with the mongrel to keep up
purchased one of these, the box is coming out anyway and i think i've killed the oem mount. Fitting kit for the diff is on its way, diff on its way. Will hopefully have a big update next week with lots of pictures of a gearbox in bits and a diff going in
Excellent :) got my engine and gearbox mount to fit too :)
have you replaced the bottom one with a Vibra-techics as well or just poly bushed that? i went for a powerflex and does the job nicely, had them on my octy vrs before and was pleased with the results
I've got the super pro dog bone insert. I heard the vibratechnics dogbone would be evil on the diesel
Yeah I've heard that too, awesome gti say it's no good for the diesels. Going to make a rear strut brace soon as well not spending £100 on a Forge item
Now this is proper engineering at it's best :)
Why buy it when i can make my own for nothing, that's what my car is all about my 3" tip cost under £50 to make better than £200 for a Badger5 item and it works just as well
Awesome that will be good. There's been a couple of members make some previously, which worked well
Been contemplating a 'X' brace but not sure of the advantages over a normal brace if any. A weld in bar with a 'X' could also be on the cards, either way its on the jobs list before combe
Let me know how you find it :) interested!
will do Jack, i will have some pictures too
this is actually out of a BMW E36 but you get the general idea of what i'm thinking for the fabia
What about a weld in half cage? Something you could make your self?
And epic project. Had a look round this at blyton.
cheers Dan  :rofl:  not really because i still need to use the rear seats, its my only car so i'm limited to what i can do
Diff fitting kit arrived yesterday, diff to be delivered this morning, ramp booked for tomorrow morning, awaiting on gearbox mount. If AMD can turn one around in 6 hours i'm going for at least 8 because i have never fitted one before, but there's a first time for everything
Good luck with the fitting mate. Did your gear box mount come with nuts and bolts?
Mine had the bolts but no nuts ooo err lol
Its a no go, wrong diff
Yes mate it did, has yours? I got mine from Awesome GTI
Mine was exactly the same, wrong bolts and no nuts. Didn't have any nuts to hand so cut the welded nuts off the stock mount and used them lol.
Aww man that's not good :(
Mine came from awesome gti too. Luckily I had a couple of nuts to hand that I used
I know but should still be able to sort something out i hope.
Fingers crossed.
This beast must be at Castle Combe!
