What Mods Have You Done To Your Car?
+1 for pictures of the grille
  • Replies 223
  • Views 84.9k
  • I have a full set of curbed alloys donated by my wife, plus a bum cheek divet on the n/s drivers door supplied by one of my kids who was probably being too lazy to close it by hand. Other than this th
  • The side skirts are great, subtle but nice. Ps I WANT THOSE 19" extreme alloys :-)
Guys ;) If you click on my username profile and then gallery, you should see 2-3 pictures of the front grille, in time, I will be doing a better job on the grille & spray the lines, red & green rather than the wrap but the wrap does the job for now
1) DTUK FSR+
2) Black magic front grille
3) OE Mercedes LED DRL's grafted into the fog light housings
4) Dedicated 10w LED cornering lights
5) DTM front splitter
6) 50w HID ballast upgrade and 5500k D2S bulbs retaining AFS functions
7) "twindicator" sequenced rear LED indicator mod
8) LED front indicators
9) Multiple VCDS tweaks
All that and it's just 2 weeks old :-p
E13EE939-8240-4E4B-8BA7-1E14B7464E9B_zps
DFFD317D-DEDE-43E7-A350-D77E4ED20CF6_zps[/url
[url=http://youtu.be/R1N6Gl6vU5Q]http://youtu.be/R1N6Gl6vU5Q
Edited by xpower
How do the 'twindicators' work and are they road Legal? I can't decide if I like it but it's certainly something I have never seen before. It does look good but is it safe?
I'm in the same boat - I did them but still can't decide. They do look better in person as they are brighter and much more visible than the camera shows them to be.
Legal - as far as I can tell having spent some time reading the MoT manual they fill the required criteria, although just because something passes an MoT doesn't necessarily make it legal. They closely mimic the operation of the sequenced indicators fitted to Ford, BMW, Audi's etc but not exactly the same.
Once fitted they can be switched over between sequenced or flashing simultaneously to double the brightness of the indicator. These are LED replacements for the std 581 bulbs and are significantly brighter:
It just involved fitting the Amber indicator lights where the reverse lights go and reprogramming their function with VCDS
I'll go against the grain here. It looks like you've got some sort of electrical gremlin. Not a huge fan.
So what happens to the reverse lights then?
Having watched the video again I'm leaning towards the 'dislike' camp, it looks a little odd. What do they do when the hazard warning lights flash? Do the outer bulbs flash on each side at the same time then the inner or do both sides flash independently of each other? The Audi lights have several LEDs don't they, that flash in sequence from the inside of the cluster to the outside?
Change the bulbs - 1 blue 1 red and you've got an unmarked police vehicle!
xpower
Please tell us more on how you have done this?
Steve
Yes, the hazzards flash inner then outer together.
Like I said, I will try it for a while and if I don't like it I can switch to simultaneous pulsing. Again they look better than the video shows.
The reverse light is now triggered by the L/H fog light channel which is set to inactive by default. I have 4 x 1w LED beads on a plate facing down and lighting the reflector up when the original reverse light would have been.
TBH - I'm not happy with the brightness, at night time it is fine but day time could be better, I'm going to look at higher power LEDS to replace them with
8A45E9D8-C3F8-4AE3-8120-7112CDC627C3_zps
The more I watch it the more I actually do like it! The hazard flashing looks smart too. It does look very much like a unmarked police vehicle, I wonder if the local plod will ever say anything, we all know they are not all that clued up with lights. The reverse lamp being activated by a different channel is all wizardry to me so excuse my ignorance when I ask if you have to code the L/H channel to be triggered to activate when reverse is selected? I take it the indicators are coded to flash the original indicator lamp and the reverse lamp (which has orange bulbs now)? Looking at them again I am certainly coming round. Videos never do lights justice.
The new improvised reverse light does look dim in the daylight, I wonder if there is anything you can do about that? First thoughts would be can you somehow integrate one of the Phillips DRL units into the rear bumper near the reflector unit and wire it to the new reversing channel? That would be super bright but not sure if you could make it aesthetically pleasing.
You are correct with your assumptions, I think the channel for the L/H fog light is 26NSL, all you do is set channel 4 (which is set to inactive) to reverse light. Then attach the power cable from the LED to that pin on the light cluster.
I am toying with different ideas for the reverse light, problem is I want to keep it as OEM looking as possible.
I have been looking at moving the position and using a dedicated unit but locations are sparse.
As for the police or emergency vehicle, I don't display a white or blue flashing light so that will be ok. It's no different than a recovery vehicle with flashing ambers on, it's just making the vehicle more visible should the unspeakable ever happen :-)
And the hazards do look super cool in person :-P
noticed a new audi a6 with i presume led horizontal rear indicators that worked in a different way to usual
instead of blinking on-off-on-off they went o-o-o-o-n off o-o-o-o-n with the orange LEDS lighting up sequentially. looked good
  • 2 months later...
Today I fitted the kiddie mirror and the bumper protector
6d3df97f0b51d2f008463c3ec600361f.jpg232e046d6c5d661b767a1aff00e934f6.jpg0a5bee31d845eab43f3fa03c0af66ac8.jpg6fee9838ab9ab0cfc2f58c153f9f43bf.jpga66e266ee08489f8c7d11ae625c6fb4d.jpg
  • 4 months later...
Fitted the milotec rear diffuser today. No dramas and can easily do with one person and some masking tape despite the instructions. Recently installed the apr turbo muffler delete which was a little more tricky but a nice wee mod for beginners.
Is this the one mate?
3231_0.jpg?XTCsid=9845aa5f0e6de964e5315c
If so, it's next on my list! :wub:
Eibach sport springs -20mm
20mm wheel spacers rear, 10mm front
VRS seat handle inserts (Superskoda)
Rear door "VRS" scuff plates (Superskoda)
LED No plate lamps (Gen VAG)
LED reversing lamp bulbs
LED white interior bulbs
LED boot lamps (Gen VAG)
LED door mirror puddle lights
Gen Skoda carpet boot liner
Vibe duel coil 6.5" sub and enclosure (in place of the puny Canton attempt)
Gen Skoda mudflaps
Rear under bumper diffuser (Superskoda)
Rear upper spoiler (Superskoda)
Rear part of roof and upper spoiler painted black to match sunroof surround
K&N panel filter and smoothed de-finned airbox
DTUK tuning box (approx 300bhp)
DTUK pedal box
Private No plate that reads BRISK VRs
Looks good that! :thumbup:
Do you know the part number for the VAG LED boot lamp?
I like the front splitter v1, I'm tempted
I'm thinking about the Spoiler Cap in Gloss black.  I think it's an alternative to removing the rear spoiler and getting it wrapped.
Meteor Grey 230 with a  Panoramic Sunroof so I'm going to get the rest of the roof wrapped gloss black and a Black spoiler
I wanted my roof doing (mines an estate), in fact it even went to the place, but when they started poking around they were not confident about all the airbags in the roof when releasing the roofbars.  For your info, 3M do a Black Magic match (or whatever it's called) which is the metallic that the Black Pack (grille and mirrors) actually is.
That's it mate, take the plung. Installed in no time and have had no bothers. Good luck
Thanks for that, I'll look into the Black Magic wrap
Hoping to get my mitts on the 230 in a couple of weeks.
So had my car for 4 months. In that time I've done the following
Interior Lights swapped to LED
LED Rear Number Plate Lights
LED Reverse Lights
Swapped DRL Halogen Bulbs for LED
LED Footwell lights
Black Front Skoda badge
Removed HI-vis vest carrier and added underseat storage box. (now containing 2 hi vis vest and breathalysers. Guess who has been to France recently)
Added rear boot lip protector
Added storage nets
Added storage bag because..
Added 2 Amps, Bit one and Sub into spare wheel well, with some Rainbow Germaniums.
Added 3 storage bins
Added Front Dash Cam
Front and Rear Mud Flaps
VRS Style foot rest from Superskoda.
LED Fog light bulbs
Lots of VCDS tweaks
In the works
Rear Dash Cam
new wheel centre caps - current ones are suffering whiteworm.
Maybe rear parking camera
Maybe bonnet lifters
Edited by WayTooTall
Added another addition.
Fitted
Eibach Springs
VWR High Flow Filter
New
Milltek Catback exhaust (Non Res)
So far (2 months):
Black cap for washer fluid
Porsche 911 cap for coolant
LEDs in interior lights
LED number plate lights
RS footrest
Phone-holder with charging
Genuine Skoda mudflaps front and rear
Genuine Skoda boot lip protector
Genuine Skoda RS sill guards for rear doors
Genuine Skoda sport decor on doors and boot
Genuine Skoda double-sided boot mat
Genuine Skoda bin
Team Heko wind deflectors
H&R 40 mm lowering springs
Japan Racing JR21, 8,5x18"
Osram LEDs for reverse and turnsignal in the rear
LED for rear foglight
Some Rieger exterior styling parts and a non-resonated Milltek are things to come during the winter...
Very nice mate. What is the phone holder with charging?
