What Mods Have You Done To Your Car?
Stage 2chip made by vtech and give me aprox 114ps over orginal bench test( 234hp), full unresonated milltek without cat, extra bosch fuelpump and progressive btr, modified nozzels.
Thanks, my English is so and so but my Swedish doesn't exist at all, so it's not easy to read from www.vtech.se
Is it a remap, or other? How much does it cost?
  • Replies 223
  • Views 83k
  • I have a full set of curbed alloys donated by my wife, plus a bum cheek divet on the n/s drivers door supplied by one of my kids who was probably being too lazy to close it by hand. Other than this th
  • The side skirts are great, subtle but nice. Ps I WANT THOSE 19" extreme alloys :-)
Found the link: http://forums.tdiclub.com/showthread.php?t=439441
post #2
TMWNA I can't check the existence of such a cylinder pressure, can you?
No neither can I check this "learning" but, no mention of it comes from VAG anywhere and to this date, all I know is that dealerships take a download of the checksum value of the ECU program thereby, allowing them to know if the original map has been removed/replaced, this in itself will only get you a TD1 flag and as far as I'm informed dealerships don't even know the result of checksum value let alone remove remaps.
Aside from the tuningbox and pedalbox remaping the DSG is the most productive of performance modifications, having a hard change-up rev-point allows your car to maintain its maximum torque rather than chasing the upper revs that sound so much faster than they actually are.  When you do go through this DSG remap process its quite surprizing just how low down the rev range you start loosing torque and when you consider the gearing just where that rev neddle will go back to on the up-change will have you double checking your figures but, you can't argue with the math and when you drive a car with the DSG remap you just know its really shifting but, it all seams so effortless because you ain't chasing that redline.
Edited by themanwithnoaim
No DSG here, sorry, only good MQ350 :)
Frallan, thank you for the info on vtech. I still have a question, are you on standard suspensions?
Edited by Genoa1893
It's not were it tails off its were the torque comes back in that counts.
On that picture its standard, I have mounted h&r lowering springs now but they could have been 1 to 2 cm lower in the front. But hey I live in a country with snow 6month / Year so lower would just screw my front spoiler in the winter..
Thank you Frallan,
it really seems I must decide and go with the H&R springs!
I really like the seats in our Elegance, but one thing does feel like it could use some improvement, the headrests. They're far too back to be able to actually comfortably rest your head on them while driving.
I was wondering if it would be possible to replace them with the adjustable type that's used on the new Passat for example. Am I correct in assuming they might be compatible?
2015-VW-Passat-rear-seat-at-the-2014-Par
Does anyone have any facts on the headrests?
I must admit I`ve never had the urge to actually rest my head on the headrests
Maybe you would if you had new S class headrests :D
Don't the buttons allow the head restraints to slide backwards and forwards?
They're not really there as a rest - more to prevent whiplash in a crash.
They do on the Passat but not on the Octavia. Which is why I'm interested in the Passat headrests.
For my TDI vRS all it needed was a DTUK tuning box!!  238bhp, tonnes to torques...  A really noticeable difference to the cars performance and ‘fun’ factor.
Hi Matrix2020,
I have just purchased the DTUK tuning box for my car. How easy did you find it to fit???
Also, in the event that I struggle to fit myself, (haven't looked at the instructions yet or attempted to fit) where in Hampshire are you and would you be prepared to help???
Regards
Mark
Just a few thousands kilometers and nine months old, but I decided anyway to repeat the "cage mod" (as on tdiclub) already applied to my old PD170.
Added a TDi badge as for some reason mine didn't come with one post-43865-0-08228500-1431968425_thumb.jpg
Hi Matrix2020,
Regards
Mark
Hi Mark, sorry for the delay I have been away for a few days.  Its really easy to install, the instructions worked well, although I did loose some skin removing the connector on the left hand side of the engine!!  Put the box in a water proof bag in the gap recommended, I ran  the cables as they highlighted.  I am in Bristol or Hampshire if you need a hand, away this weekend though.......  Good luck.  DTUK were very helpful when I called for some settings help,helps they have one fitted to their vRS!!  I think I am running it on 3 +1?? But if you give DTUK a call mine is set to the same as theirs.  2 + 2 did not work for me, it felt too jerky at 2000 rpm.
So far mud flaps and a skoda and Octavia debadge
  • 2 months later...
Front splitter.
NEXT
1. K&N air filter fitted
2. Diffuser fitted
Have you noticed much of a change in performance from the air filter change
Edited by POL999
Haven't got around to it yet, but when I do have it installed I'll post my views on here of it.
  • 4 weeks later...
Seatbelt covers
Middle compartment cover (VRS logo on each side)
Subtle - All from SuperSkoda.com.
Edited by Chayy
Had my vrs estate a few months now,mods are as follows:
De badge
Mud flaps
VWR golf r springs
19" Xtremes
12mm front spacer
20mm h&r bolt on rear spacers
A few vcds adaptations
Need a black grill next I think and maybe a dtuk tuning box
De badge
Mud flaps
VWR golf r springs
19" Xtremes
12mm front spacer
Pictures?
Have you used SuperSkoda.com?
Such a nice colour for the VRS  :wub:
Looking forward to getting my Fabia Monte Carlo combi in this colour later this year  :D
