Windscreen washer fluid level warning...or lack of it
Encountered another issue with the Spacebacuk last night, albeit a small one.
My windscreen washer fluid bottle ran dry (never good as running dry increases the chances of sucking up dirt, grit and any other crud that might be at the very bottom of the washer bottle, potentially blocking pipes and even blocking the pump).
Anyway, the more annoying thing was that this car is supposed to have a sensor in the bottle to flag low fluid level - but there was no warning light, no Maxi Dot message or anything.
Anyone else encountered this?
Chris
find someone with vcds to see if it is coded
Fairly easy to retrofit
It should not need retrofitting - it's a documented feature of the car in the manual so the sensor should already be there. It's either a software issue or the sensor is knackered. Given the other issues I've had with the car, my money is on the latter.
Will be on the punch list of issues for my local dealer (not the one I bought it from) to address next month when it goes in for its first service.
If fitted it needs to be coded in
If it is coded in and it is not working then you would have a warning, unless you have a wiring short to ground
my bet is on it not being there
How far did it run to the first service?  My dash is estimating 18700 miles.
Off the top of my head I can't remember the dash estimate, but I don't think it's too far off that number (actual current mileage is 7,400). However, end of December will be 12 months since 1st registration and I'm not letting the car go any longer without an initial service.
Just as well given the list of things that need addressing under warranty.
Chris
I do not think it has a warning or anything could only be eu and not uk spec.Takes 3.5 lts to fill or 5.5 lts if got headlight washers i check and fill every week
Have you got the headlight washer add on package. I think the sensor comes with that.
Chris
Hi Chris,
Does your car have the long life oil in it and does your driving habit suit this service schedule. i.e. typically 50miles a day and not hammered. (car will tell you when needs serviced typically 9k to 20k miles)
Or if you are short commutes and lots of stop start etc annual or 10K miles.
Its in the car code in front of service book.
I just changed to annual (wife retired and driving Rapid)
Option code QI6 on the sticker inside front cover of the service handbook, indicates long life oil and flexi-servicing.
Option codes are also on a sticker near the spare wheel well
Edited by camelspyyder
camelspyyder,
Thanks for techno info.
Will have a look in the morning. However, as I don't know how the car was driven or otherwise cared for prior to my ownership, it'll have a full service in a few weeks regardless. Oil and plugs are cheaper than a new engine :)
Good idea.  However you should tell the dealer if you want to stay on flexi or change to fixed servicing.  The oil grades are different for one thing and the service indicator reset.
Yes, good idea,
I bought my 1.4TSI DSG Skoda approved car from dealer RRG in Rochdale who assured me it had easy life. Turns out it was hire car. It was "serviced" last October and i think it never moved until i bought it in March. It has been faultless so far (booming excepted).
But now serviced at 22k miles and all software updates done and is running very smooth (touching wood)
Intention is to keep for a good few years, so trying look after it and adding the odd accessory to make life cool and laid back.
Bidey fae Perth
Back to the washer empty warning light.  I had to ask my dealer this asd was told NO it does not have one.  When I asked why as it says so in the manual was told
The manual covers every car in every country so cars vary in what they have.
Owner's manual page 36
If the windscreen washer fluid level is too low, the warning light illuminates.
The following message is shown in the MAXI DOT display.
Top up wash fluid!
I've not experienced it yet, but my friend told me that this warning light does illuminate when iginition is switched on, but not after starting engine.
No fluid and no warning = no sensor.
It won't have one and those manuals are so generalised. Can be retrofitted easy apparently [emoji106]
I do have the warning to top up washer fluid. It shows the warning light and a message upon starting the engine. Then the light is lit constantly
