Tyre size for vrs
So the vrs is going to be due a new set of boots soon into the new year, i am looking to try a set of federal 595 rsr's in 215/40/17 but my question is has anyone tried the 215/45/17 size on the vrs???
Thanks in advance
Wrighty
Yes a couple of members were running 215/45 R 17,  but they really are to big by total diameter / rolling circumference.
The Federals should be perfect in the right weather/use.
215/40 R 17 is perfect size on a vRS it is the standard size on the sister cars,
 but they are not necessarily bigger physically than some other brand of 205/40 R 17.
Brand & type dependent.
ie Pirreli 205/40 R 17 can be as big as some of Brand of 215's,  but just not as much tread width.
They are bigger / taller side by side than my M+S marked 215/40 R 17 Goodrides.
(The measurement comes from the wall width and some tyres have rim protectors)
http://kouki.co.uk/utilities/visual-tyre-size-calculator
Edited by goneoffSKi
Thanks tattyjay and George, I forgot to mention that I had used search tool but not found that thread, that's cracking info!!! The standard continentals look a bit silly because they are stretched to the rim width, I always liked the oem set up on my mk1, thought that was spot on.
