Electricity turnoff issue
Recommended Posts
Hi guys, any advice on how to turn electricity off in the cigarette lighter socket in my 2014 Octy? I've set up a dashboard camera, and it stays switched on after I switch the ignition off and remove the key. The same goes for the power adapter.
Thanks!
Link to comment
Share on other sites
You'll probably need to find a fuse under the dash/glovebox that's switched with the ignition and hang a piggy-back adapter on it.
Edit - both 12V sockets are on the same fuse under the dash hence they both work the same way.
Edited by Smeghead
Link to comment
Ok, thanks guys!
Link to comment
Wonder if the opposite is true to the Seat Leon and VW Golf which have ignition switched sockets
http://www.seatcupra.net/forums/showthread.php?t=402881
You need to pull down the glovebox (it's explained in the manual) to reveal the fuse box, in the middle of the fuse box you will see a yellow 20 amp blade fuse (location f40)
You will notice it sits a slight bit lower than the green 30 amp fuse to its left.
Remove the yellow 20 amp fuse,now move it up slightly until it is parallel with the green fuse next to it, push the fuse back in.
Your 12 volt accessories socket is now permanently live
Best of all its easily reversed if you change your mind
Link to comment
Interesting.  I'll try pulling mine out later and see.  I don't suppose you have a picture of the Leon fuse box, by any chance?
Link to comment
This is a Golf fuse box. It's not the red circled fuse but the yellow one beneath. Look at its position; you can move it up to the same position as the green 30 amp beside it. This is not my car and I haven't tried it, just what I've read on the Seat forum. YMMV!
Link to comment
May look at this as I sometimes put an electric cool box in the back of my estate, and forget to unplug it when I'm parked up at the shops etc.
Link to comment
+1. Plus dash cams etc.
Link to comment
I can confirm that on the Golf the yellow position fuse is designed to be put in either of the 2 positions so you can choose whether the cigy socket is live all the time or switched.  Should be exactly the same in the Octy, why the different marcs choose different starting positions must be simply brand choice.
Link to comment
You mean like this?
http://www.golfmk7.com/forums/attachment.php?attachmentid=2209&stc=1&d=1407846798
Interesting that the pics of the Octavia fusebox on this thread show it already in the lower (switched) position http://www.briskoda.net/forums/topic/294828-fitting-a-multiway-cigy-adapter-to-a-mk3-octavia/
Link to comment
You mean like this?
Those pics are of a mk7 golf.....
And the difference is...?
The golf come with the fuse in the switched like position, but if you'd have read the post i'd quoted you wouldn't have misunderstood.
Link to comment
I prefer having a permanently live 12v because it allows my dashcam to record events after I leave the car. It's ideal for Tesco/Asda car parks.
+1. A dash cam uses negligible load compared to what the battery can supply.
Fridge/cooler though it would be nice if the boot one was switched with the ignition.
  • Like 1
Link to comment
I'm thinking of doing this with mine currently. As it stands I've got everything wired in to the switched rear wiper. How many cameras do you have and what's the longest you've left the car without using it as I'd like to know if it's worth making the change?
For anyone after the removal for the Glovebox instructions thread with the video it's this one - http://www.briskoda.net/forums/topic/338347-getting-the-glovebox-out/
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
