Recommend me a multimeter
  • Replies 53
  • Views 6.7k
  • Another telecom engineer of 26 years here..... With the railway rather than BT though..... All the older guys used to use the Avo 8 meters when i was out in the field years back. I never got one as we
  • Just bought this off ebay, as good as new £60 inc delivery
  • I'll let you know in three to five working days, Wayne
I just went to Screwfix and bought a £20 for cars :)
Does have a Beep for test too ;)
got a linky, Wayne?
Audible continuity is always a plus (very good for checking wiring looms), along with decent length of wire on the probes.
I've got a fluke banging about Lee. Fluke 12 I think it is
well, it was more for dual purpose as I'd buy another for work only for testing continuity on the pairs  between the cab and the DSLAM. :D
any good as a brand, are they?
Fluke are good but nothing near £30, most are north of £150 I used to use them at work with additional probes to check for temperature etc for calibrating hot drums on printing presses.
that's still cheaper than one I saw for over 1K :o :no:
+1
Fluke are very good - but expensive :(
My Dad has that one too. It is well more than 15 years old, at least 40. His was given to him when he moved jobs by his old company in the mid 70s!
Several thoughts on meters, and my wish list.
1) - AUTO RANGING if possible - so if working on car, you select volts DC and forget. in house, select AC volts and forget -means it's a bit ore difficult to select wrong rage.
2) with HOLD if possible. very useful if checking solenoid for voltage drop problems.
3) Back lit with auto switch off.
4) Alarm function on amps range if probes not in correct place.
5) seperate diode test and ohms range,with selectable beep function.
but thats from my top of the range, all singing all dancing Fluke. Not the sort of thing most folks would need.
Some places will try and tell you that you need the meter with the highest ohm/volt reading - used to be true on old analogue kit, where the Avo shown would be about 20k ohm/volt, whereas the cheapo i keep in the car ( free gift from a sales rep possibly worth about £2.50) is around 50-100 times that.
Advantage of digital is that it's idiot proof as regard polarity and almost idiot proof as regards range.
i've also got a Rapid which cost less than £20 and a cheaper Fluke and a cheapo which I keep in the car . It doesn't matter on the quality of meter for most jobs,just how well you can understand what it's telling you. Lamps /fuses will give a go /no go test. A charging circuit will /should be around 14v at decent revs ( and preferably with all electrics on).
At home- ( IN CAPS AS MEANT TO BE A WARNING) - DO NOT TEST LIVE CIRCUITS, WITH A METER-USE A TEST SCREWDRIVER INSTEAD.
Edited by VWD
I have three two digitals (one normal sized and a tiny pocket one) and an analogue. All were less than a tenner from a local electronics shop and have worked great for years. If your not after anting too precise and just want the basic functions pretty much anything should do. If you have a local electronics shop pop in and see what they have...
What's the reason for the warning? I always check circuits for live with a meter before I touch them having once turned power off and found a circuit to still be live the hard way.
Never had a problem with a Meter (but have killed one long time ago admittedly when I had the wrong range set)
Fed up with the Jdsu try a 9083 ,one of bt's best bits of kit
we've got one on the van, a bit more battered looking than that though :D No JDSU, we do have an EXFO though :)
I keep looking on ebay for myself but they seem a bit pricey :(
Engineers have been buying off eBay for years because being analogue it can be left on waiting for an error to show where the digital meter only looks for an instant in time.also there are 18c meters which are a lot bigger ,more sensitive but will also measure faults.
Guest
