Mudflaps
Anyone got part numbers for the facelift Octavia vRS Hatch?
Yea the normal gen skoda ones do for fine on the fronts but have a small gap on the rears :)
As above but they do fit. The fronts will fit easily by turning wheels to full lock and using IIRC a short crosshead or philios screwdriver. The rears are a bit more fiddly and are easier to fit if you remove the wheel first. I used some black silicone sealant from Halfords to help seal the rears and prevent water and muck getting between them and the inside of the wheel arch, but you might not need it if you fettle them a bit first and get them nice and warm by putting them in a bucket of hot water to make them more pliable before fitting. There's a thread in the mk2 section on this somewhere if you want to search-try blackline as it was a popular thread at the time they came out.
Ah so similar to the Fabia Estate then. I remember there was a fuss when I ordered for that as Skoda wouldn't approve that they would fit. They did fine and if anything it was the fronts that were only slightly out. Then a customer saw mine with them on who asked the dealer about them, along the lines off "how has he got them but you told me I can't?"
