replacing springs and shock absorbers
Hi guys,
I'm planing to replace my shock absorbers and springs in the next few days. Which setup would you recommend for balancing performance/steering response vs comfort when driving over bumpy roads ?
There are already a number of posts on this subject.  A search will find you plenty of information and opinions.
I've got Sachs front struts and Meyle rear dampers. It rides and handles fine. I didn't change the springs though.
I'd fancy for a set of Bilstein B8s + Einbach Pro-kit. How about this setup ? Should I chose different springs? I've done some online research and some of the customers are not so satisfied because the car wasn't leveled equally (front vs rear).
Is there any noticeable difference between this setup and the Einbach Bilstein B12 Pro Kit ?
Edited by Alexandru
standard OEM springs & Koni FSD dampers & poly bush the front wishbone rear bush (console) with a two piece powerflex or superpro version........................
Best comfort/handling set up IMO............
I tried to find a set of Koni ones, but there are no dealers which could sell me those, so I had to look for alternatives.
eh??..............phone up Koni UK direct .........I got mine from demon tweaks.....
I can't really do that. I'm not from UK. :)
I don't think it's worth spending much on the suspension on an MPI. The performance isn't exactly earth-shattering.
I agree, but I'm not really doing it for performance reasons, more for handling. It's a slowda, so it's not really going to be a 10 seconds car, but it might perform better on corners. This is what I am planning to enjoy this summer
along with some others.
^ Scary road :o
I'd preffer to call it fun. New tires and suspension should keep me off the cliff. My car has no ABS or traction control though...but it's ok. :)
No ABS? That's weird, I thought they nearly all had it.
Nope, not even ABS. It's a comfort version, from May 2000.
My MPi had the following
Koni RSX coil overs
Fully polybushed
Cupra console bushes
Momo strut brace
Rear brace
Front lower brace
Jabba rear anti roll bar
vRS front anti roll bar
Wasn't a waste at all, handled brilliantly and was great fun to drive as the front end was nice and light, once it was wound up you could keep it going.
That's exactly my point:)
I took a gamble and fitted these: http://www.ebay.co.uk/itm/221687104103?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
with :
http://www.ebay.co.uk/itm/251906482217?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
£176 for full setup :p
No idea how long they will last .. so far so good
Ohh we are talking more than the OP mentioned ...
I have polybushed inner and outter wishbone bushes, seat sport strut brace, whiteline RARB
Koni RSX coil overs
Fully polybushed
Momo strut brace
Rear brace
Front lower brace
How did you find the braces as I was always temped but never did........
but did this:-
Koni FSD dampers
OEM springs
Powerflex console bush, front wishbone bush, front ARB bushs, rear beam bushs
Superpro dog bone rear bush
bigger diesel (not vrs) front ARB
when I re-did the suspension I renewed all nuts/bolts/top mounts etc with oem.........
also braking was EBC discs & green stuff pads back & front
EBC fluid
Stainless goodridge brake hoses on front & rear beam.........
Plus a few other mods............. :sun:
I can see that you replaced the oem bushes...does this also affect handling? I mean, my car might have the oem ones, can't tell for sure, they don't have any play, but I'm not sure if I should replace them yet or should I wait until the current ones will fail.
Console bushes are about the single best mod you can do, the factory ones are shocking.
Do you have a link for them ? Sounds pretty neat.
I'd say go for it, the Eibach springs are perfect on bumpy roads and the B8 dampers are uprated so should also be perfect, the springs will lower 30mm on your car.
Get a RARB with the money you save from not buying the B12 kit and polybush the consoles, handling will be excellent, mine is set up this way and the only mod left is to find a way to stiffen up the PAS, I'm looking to fit a hydraulic flow control valve inline with the rack so I can adjust the steering feel, it's just too damned light even on the heaviest setting.
I had to pushstart my car once, when my ex-battery decided to die. The power steering didn't come on (I guess it didn't have enough amps to boot the system), the warning light was in the instruments panel, but the feeling was flipping awsome in the 5 miles that I've driven the car just to charge the battery. The only way to keep it off is by disconnecting the fuse IMHO. Most of the torque required for steering is provided by the electrical motor and not by the hydraulical system. Driving it around corners was briliant, but don't try a paralel park without it. Been there, done that... :angel:
Later edit: keeping the hydraulics in the original state/configuration might be the only way to keep the rack in good condition (mostly for lubrication), otherwise it might get nasty.
Edited by Alexandru
Have a search on here, be a million threads on them.
Nope, it's just an ordinary hydraulic PAS system with an electric pump, I'm going to fit an adjustable flow control valve to the pump output so I can tune the pressure and program the pump to velocity sensitive mode 00140 so the assist increases at low speeds.
You're forgetting I'm an engineer, I've thought carefully about this:
http://www.flowfitonline.com/acatalog/Online_Catalogue_BARREL_FLOW_CONTROL_VALVES_NO_CHECK_344.html
