Where to find the outside temperature sensor on my Fabia mk1
The outside temp. sensor started a few days ago to show --.-c, and i noticed a plug hanging below the car. I need to know where the sensor is to reconnect it. Does this affect any function in the car, like the A/C?
It's located behind the passenger side fog light grille :)
It doesn't affect anything els to my knowledge either :)
except the A/C; the A/C won't work if the outside temp is < 50C Not sure how it would affect things if the car doesn't know what the outside temp is :think:
Unplug it and see if it switches off completely then :)
Ac will work if temp sensor disconnected, my old ibiza does when I had a dodgy sensor
That is weird, I would have thought that broken/open/disconnected sensor would tell the AC outside temperature was below its lower operating limit.
The sensor just displays --.-c but ac will still work, which I admit is strange but at least it still worked lol
Oh well, that is handy at this time of year, might really depend on what the system thinks the temperature is, what you are saying is that O/C = HIGH temperature and S/C = LOW temperature - that is probably true as most "normal" resistive temperature sensors increase their resistance with rising temperature, I stand corrected.
  • Sponsor
It's an NTC thermistor (just checked, warmer = lower resistance), but I reckon the ECU interprets  (both) extremes of resistance as open-circuit or short-circuit wiring rather than mad temperatures, reports/stores a fault code, and then defaults to using a 'normalish' temperature to let the AC carry on while things are mended?
Thanks all for the info. Actually my A/C works fine, inspite of not knowing what the outside temperature is!
