Rob's Ur Quattro
Got a few minutes to do a couple of small jobs.
The easy to get to engine mount is done :)
16587279_962002213900075_611800528835721
16664971_962002310566732_793948009532058
And pulled the rusty radiator cowl off and slapped some paint on it :)
I reckon that rubber flap might be past it.
16711607_962540080512955_307837854622828
16641047_962540137179616_137658154679384
  • Replies 1.7k
  • Views 175.2k
  • Went to the supermarket while I waited for traffic to die down a bit. Second supermarket car park of the evening. Terrible pic, it was getting dark The drive home was uneventful. L
  • RobClubley
    RobClubley
    Back on its wheels at last!
  • Wento for a quick trip to the petrol station. Got sidetracked. I am loving this car! It sounds like it's gargling on the fuel not just drinking it, what an awesome sound!
Check out my rusty turbo. As expected of course. Not looking forward to the day I have to remove those nuts!
16708259_964666010300362_702077977604976
16797034_964663210300642_675270763857567
Driver side engine mount in place, with rusty nuts :D
It's a bit different to the one that was fitted but it fitted okay so I went with it :D
16708260_964677700299193_236241622159547
16602273_964677663632530_593829984543911
16797197_964677623632534_128592592522762
16797365_964677820299181_531500311078245
That looks a lot like a K&N filter. Have I found the first decent part fitted to my car? Needs a clean of course.
16730525_964678523632444_783784966025385
You cold give the turbo nuts some PlusGas now?
Sigh. Managed to drop the sealing washer from one of the banjo bolts on the fuel line. Of course it didn't come out of the bottom. Will have to take the airbox back out to look for it.
So instead of doing that I made a rubber flap thingy.
16715907_967669989999964_312808593222546
16797850_967670379999925_408978541521488
16797718_967670773333219_568354914451850
16715876_967670976666532_430303687470363
I failed to find a new washer at any local car shops, then I remembered the donor car, and found one on one of the bits. Got it all back together then looked over and noticed this gasket. I used all of the swears.
16649473_968020673298229_522858749652822
Oh look, something was broken.
16864177_968025393297757_734165485304304
16832111_968025416631088_668616228628934
16681692_968025396631090_187012616623731
This looks okay in a photo but really rough in real life!
16830981_968026639964299_328460619530737
The radiator's back in and looking a bit tidier.
16835961_968028066630823_466145423297773
16819442_968028033297493_120453407770472
You're getting the Rob, keep it up mate.
Just keep thinking of the end game...you'll end up with a rare v interesting car that'll be worth decent money by the end of it.  The hard work will all be worthwhile.
Looks a bit better painted.
16903366_972070656226564_214566154165177
Got some bits and pieces delivered including these exhaust hangers and brake caliper seal kits.
16904748_972784792821817_299946855605903
I sprayed a bit of degreaser around under the engine. Super Cheap's own brand, it's pretty good.
16903388_973722896061340_633141564746097
Front subframe with some paint slapped on and some nice new poly bushes and mounts attached.
17016049_975405265893103_878686503901918
All of the ABS sensors have lost most of their outer shielding. What's the best thing to re-wrap them? I'm optimistically assuming they work :D
17039073_975407575892872_543837747832975
16998682_975408309226132_518894090958944
With the plugs fitted l'd probably wrap them with loom tape them put a spiral cable wrap over the top because of the harsh environment.
One lot of exhaust bolts removed :D
17038843_976833115750318_964275160386001
Exhaust removed at last. It's not great.
16939462_979047482195548_919171457253938
17097425_979047632195533_100977912500296
15589555_979047785528851_865330672642249
17103246_979047965528833_752756019862371
Front wishbone bushes removed. It went well so I decided to do the rears as well. Yeah they're a bit rusted in.
16864840_979049858861977_159617983754131
17097402_979050018861961_390059383986274
Removed the drive shaft to clean it up and sort out the CV boots. This might explain why one wasn't attached - the part it's supposed to seal to isn't round!
17015835_979336198833343_262795032746999
17155700_979334945500135_143070856828718
Looks like this is where all of the CV joint grease ended up.
17022404_979337835499846_224051776268786
17022291_979337828833180_851412843620638
Edited by RobClubley
A box of bits arrived. Swaybar end links (the correct ones this time), Rear tie rods and bump stops.
17157481_982770931823203_127921477459618
Looking at shocks now, it seems the fronts are either 50mm or 55mm diameter. Will measure tonight and find out which I have. Bilstein B6 are the ones I'm, going for. I've asked a few NZ suppliers for pricing. I'd like to buy locally but not if there's the 50-300% "being in New Zealand" tax.
Both struts have 55mm outer diameter, so I've gone for it and ordered the Bilsteins. Found them from an NZ supplier for a reasonable amount.
Got some odds and sods from Classic Quattros in the UK:
The plastic air guide for the intercooler, which I'm missing. Pipes for the headlight washers, proper clips for the bumpers, a new trim for the passenger door, and some neoprene strips which should be between the two parts of each bumper.
17310217_988215294612100_743915204233007
17309936_988442484589381_223959498155585
Oh and the bag which should be in the boot to hold the tools.
Much excite...
17309264_989149604518669_327908166856419
17218601_989149804518649_412843330676474
Car loaded up to take some stuff to The Toy Shop Wellington tomorrow for some assistance with things like wheel bearings.
The timing of the shocks arriving was spot on!
17310931_989160044517625_232460353505888
Just caught up on this years updates B)
Epic restoration, but expected that after your Octy estate!
Really looking forward to more updates and the finished car :)
The Toy Shop Wellington are doing a great job on my struts, having to use some creative methods to get them apart after the wheel bearing refused to shift with 10 tonnes of pressure.
It appears I supplied two correct wheel bearings and two wrong ones. Doh. They're sorting some correct ones out for me.
17190511_990429824390647_659191591508864
17264870_990429874390642_836248021601166
17352562_990429901057306_309483223305283
17349993_990429964390633_330296256627632
Looking forward to seeing these completed, they look excellent.
17359407_990595597707403_555494212893835
17342982_990595617707401_615539207389008
Got the brake hard lines out from each corner. The front to back one is okay but the connections to the flexis were all rusted and rounded and I had to saw them off.
17359097_991318430968453_716356995880834
I've nearly got everything removed now, I need to start putting things back on!
Rear subframe still needs removing, need to buy bushes for it as I only ordered enough for one subframe for some reason!
I moved my jack stands and had to set them higher, then the car felt a bit wobblier than I liked so I moved them back and decided to find a better way to support it. I'm sure it would be fine but I like to make sure it's rock solid before I get under there.
First attempt at making a brake hard line. The pipe flaring tool worked well.
17264949_992330227533940_136399805430398
17353598_992330327533930_268338038102505
17361585_992330320867264_645744324042733
17349586_992330310867265_314000264221189
Ref the working height thing; my mates and I used to put wheels under the chassis rails on the basis that that would catch the car before it crushed us!
Yes the original wheels are under the car, so there's 8" of protection there :D
Oh yeah...
17359121_993769917389971_746678707670563
Wallet somewhat lighter but they did a great job
17434847_993772470723049_805086425881117
B)
