Rob's Ur Quattro
I must admit I was surprised you weren't doing this in the first place, the car will be much more enjoyable knowing its' 100% sorted and not just shinny on top!
I was a bit optimistic really because I knew that the previous owner occasionally took the car out for a sneaky blast. So I assumed everything under there was at least serviceable. Turns out he must have been mad to drive it!
I was hoping to get it on the road then do the underside bit by bit.
Oh well, many more rusty bolts to undo :D
  • Replies 1.7k
  • Views 177.9k
  • Went to the supermarket while I waited for traffic to die down a bit. Second supermarket car park of the evening. Terrible pic, it was getting dark The drive home was uneventful. L
  • RobClubley
    RobClubley
    Back on its wheels at last!
  • Wento for a quick trip to the petrol station. Got sidetracked. I am loving this car! It sounds like it's gargling on the fuel not just drinking it, what an awesome sound!
The relay works for the hazards but indicators just come on solid. Need to break out the wiring diagrams and work it out. It coulds be because I fitted LED bulbs maybe :)
Working on brakes is hard work! Guess which one was stuck on.
List of parts needed is growing. At least one c.v. boot, bump stops. Abs cables maybe, brake lines, and probably hard lines as I think I've damaged one trying to get the brake lines off.
Rob,
The indicator relay works properly with the wright current. On a classic system if one of the bulbs is broken, the flashing rate doubbles almost. So the current was only half of normal. LED current is too low.
erreesse
Ah, if you've used LEDs with no ballasts then Erreesse will be right and your indicator current draw is too low to operate the flash relay at the correct speed.
New pedal rubbers :)
15626430_921885111245119_760364192552368
Hang on in there Rob.  I was in a similar boat with a Mk1 Golf years ago, where everything seemed to just open up another can of worms (mostly metal ones).  Slowly slowly catchee monkey.  As B33fy said, sometimes a bit of breathing space can do the world of good.
Pedal rubbers are a bit close together aren't they?  :p
Gaz
Gaz
He might just have gigantic feet?
Edited by Lady Elanore
The best parcels...
15675948_922924454474518_406236844398682
Fixed a little problem I had.
15672554_922962361137394_712181436070591
15665548_922962404470723_193567263504147
15590048_922962451137385_150172971471731
I hope all this money isn't meaning the Baby Kiwi Sanctuary is being neglected. I might have to move over there sooner than anticipated if it is...
Wow the eggs are huge!
Btw I like bunnies too
You wouldn't want to be a lady kiwi:
Oh that doesn't look easy!
i can see why they don't have wings. They hope to be eaten before laying the eggs :(
Small hands..... big feet...... Hobbits??  :notme:
Does Rob know Peter Jackson?  Was he an extra?
That must've been so-oo exciting - Jealous  :envy:
Gaz
New pedal rubbers fitted. The accelerator one doesn't fit, ah well.
15747374_926613064105657_641994575212047
15732460_926613254105638_868107979788717
Otherwise I've mostly been trying to loosen rusty nuts, with varying success.
15740930_927762127324084_439755932187420
15726955_927855290648101_414539281189351
15822962_927855347314762_735602062156492
That's not right!!
15724668_927855560648074_811092369890522
Front rollbar bushes, I have new ones :)
15774814_928414937258803_855999154534112
Haven't got the nuts loosened at this end. So much rust!
15776878_928417920591838_801903068170472
Plan is now to strip everything I can from suspension and running gear, assess what I need, buy parts gradually and re-assemble.
I've already bought new engine mounts, subframe bushes, front rollbar bushes, wishbone bushes, strut top mounts, rear diff mount.
Need to check gearbox mounts, though I might as well just replace them with everything else I'm doing.
Everything's so corroded, I need to suss out what to keep and what to replace. And what I can replace!
Got one strut out at last!
15780800_929123907187906_171703510117414
15740969_929124127187884_758209401132317
Rear struts are ready to come out but the shafts are rusted into the hubs I think. They're not budging anyway. The fronts came loose with a quick tap. Rears not so much!
The exhaust bolts will need cutting off I think. And I'm buggered if I can get the driver side steering rod ball joint to split.
I haven't tried heating anything yet, though. I'm doing this in 30-60 minute chunks when I can sneak down to the garage :D
Some more rusty things.
15875394_929889687111328_454256827448767
15823119_929889707111326_336381656994769
15823618_929889703777993_319099774036766
Old (right) vs. new
15871597_929890843777879_132197528983058
Driver side CV joints..
15844473_929891303777833_126085803914593
15873284_929891300444500_374558511845877
I'm not a fan of these things!
15826144_929887547111542_169851348017802
So yeah the parts list is growing.
I need to buy some more stands to hold up the gearbox while I remove the subframe. The subframe is in a bit of a state, dented and rusty and filthy. Once that's off I can get a better look at the engine mounts and exhaust/downpipe, none of which look very convincing.
I think the GT subframe was in better condition but I won't know until I compare them whether they're the same part.
Almost all of the the brake lines look pretty corroded. I hope they are possible to sort out without removing the engine!!
I was looking at these last night...
https://www.akmotorsport.net/shop/all-parts/wishbones/tubular-audisport-replica-wishbone-set-2/
Audi-Sport-Quattro-S1-wishbone-B2-rear.j
Probably not a good idea, or likely not legal in NZ but they do look pretty.
A bit more deconstruction.
15799976_930457587054538_693312620572233
15800002_930457717054525_845978019336918
Looks like the shocks are toast. Push them right in and they don't pop out again. Will it ever end?
15875183_930457807054516_299845980602797
are you tempted to drop the engine and give it a full going over?
The thought has occurred.
I started this hoping to sort the rust, fit new brake pads and discs, change fluids and go.
Oh how wrong I was.
Surprised the bodyshop didn't say anything about the underside. Don't get too bogged down with the bigger picture Just work in bite size chunks and work through each little job, you'll get there in the end. :)
Edited by B33fy
I don't know how it's taken so long? 'Wheeler Dealers' would have knocked this one together in about a week...... :D:D:D
I think after having it so long they kinda rushed it, and overlooked that part.
Wow Rob! So much work. But you've come this far, so you might as well complete what must surly be one of, if not the, best Quattro in NZ. Just looking at those gorgeous wheels must give you goosebumps and remind you of how important this restoration is :)
