Rob's Ur Quattro
  • Replies 1.7k
  • Views 175.2k
  • Went to the supermarket while I waited for traffic to die down a bit. Second supermarket car park of the evening. Terrible pic, it was getting dark The drive home was uneventful. L
  • RobClubley
    RobClubley
    Back on its wheels at last!
  • Wento for a quick trip to the petrol station. Got sidetracked. I am loving this car! It sounds like it's gargling on the fuel not just drinking it, what an awesome sound!
On 2017-6-13 at 04:25, RobClubley said:
B) - Awesome, the grin on my face was huge, I bet you were almost crying with excitement.
Is it a trick of the camera, or is the dash going out when you rev it Rob?. Love the sound of a Quattro, top work, keep em coming. :cool:
The dash is well dodgy. I was optimistically hoping a better earth would have fixed it but no joy. Could be the voltage regulator in the dash unit - they are prone to failure apparently. I have a new one to go in, need to engage my friend who knows how to solder properly.
Bit of a frustrating afternoon working on the car today. I realised I can't get the front left wheel to turn so investigated that and found that the brake caliper is stuck on. I thought it was all okay but it looks like I'm going to have to remove it and re-check it.
I removed the bonnet locking pins to clean them up and paint them as they're rusty and have been bothering me.
19143868_1060407977392831_26289613154449
Then I noticed the power steering fluid all over the place. Bugger. It's slowly weeping from the banjo bolt I removed to drain it when I fixed the anti-vibration mounts on the pressure accumulator thingy. Hardly any has made it to the floor, it's all sitting on various brackets and surfaces in the engine. Need to get some new washers I think, drain it again, clean it and re-seal.
Then I decided to look at the passenger side window. I never did get it closing properly. After some investigation I've declared the aftermarket regulator I bought to be useless.
So I need to either source an OEM regulator (rare as unicorn poo) or try and make one good one from the new motor and original vertical bit.
This thread is becoming car porn.....:giggle:B)
Brake caliper off again because it's not retracting. I suspect it may be toast. Hope not but lumps of rusty stuff came out with the fluid. And I'm struggling to get the pistons out.
19399228_1065638483536447_32652694932305
The red in the tray is ATF from my leaky power steering.
Started fitting the exhaust.
19237915_1065638890203073_82890272966396
19400198_1065639146869714_44106466848077
19441826_1065639206869708_73184314454762
At this point I declared lunchtime...
19430023_1065639306869698_61497892817149
After lunch I realised I needed to fit it from back to front to get it seated properly in its new mounts - which entailed drilling holes in my boot floor. So off it all came to be re-fitted.
19237875_1065741933526102_51067969993102
19238241_1065742030192759_10130267251951
19417313_1065742190192743_14947138232392
19390679_1065742323526063_77974056933450
19477346_1065742390192723_31591356400705
19402263_1065742446859384_54486510540736
19390791_1065742716859357_48410649689577
New bolts in boot
19390925_1065742790192683_61728703438195
Edited by RobClubley
Getting there Rob.
A new window regulator arrived. Works perfectly. But it's for the wrong side. Bugger.
19894748_1081553745278254_51112424174919
I took the digital dash apart a bit to find that voltage regulator that I'm told might be the cause of the flickering. Yeah that's beyond my soldering skills. Need to find someone who can help with it.
20017446_1083193425114286_68790700629556
19983246_1083193435114285_75090159230980
19467980_1083193418447620_87796445074858
Also a mate popped around with a G60 caliper for the passenger side. Hero. Got it cleaned up and painted and ready to fit tomorrow.
Then if that's all good I can get the car back on its wheels.
Caliper painted up, fitted and bled..
19990518_1083986881701607_45473853378833
20045552_1083986878368274_27690392747808
The guy I got the wrong window reg from has the other side so I've bought it from him. Third time lucky I hope...
It's in and goes up and down. Didn't have time to get the glass in and fully test last night.
Need to clean up the window switches internally as they are a bit intermittent.
20232798_1090449674388661_19572727296138
This makes me very happy. First time the door has been together for about 22 months!
20280547_1091296774303951_75365465993264
Picked up a box of random 80s Audi parts from another VASK member. Looks useful.
20643203_1100090716757890_19060086559838
20545297_1100090783424550_72481643054876
 Some good bits in there - lots of door handles, a brand new chrome trim for one, fuel pump and filters, lots of window switches, couple of (I think) 80 rear window regulators, some fasteners, a few KV engine parts,
And my instrument cluster is still in Christchurch at Get Electronic. Sounds like they're having trouble fixing it :(
Initial diagnosis was:
Basically a high voltage break down is happening here ether A : the transformers isolation is breaking down at its High operation voltage and sparking over thus showing it to stop or B: the mosfet drivers that switch the high voltage on the circuit are not getting full saturation and failing
Get Electronic
fixing the issue : i would start to replace the Fets (mostfets) first due too them normally being off the shelf components and the eaisist to replace quickly without trying to get the original transformer that would be ncely priority and only made by audi or rather by contract to audi  and in nothing elce so supply would be hard to get.
After a couple of weeks:
The flickering cause is still undetermined
Possibly won't be able so fix, especially if in the main micro processor
going to try jam in my own Clock signal to run the displays thats the next step
thanks for your patience too !
never expected this one to be such a troublesome unit
the older stuff is usually much more harder to repair
ICs that need replacement are no longer available to change over as parts anymore
were seeing this from about 1997 and below
20729226_1105664759533819_78984764968569
Yes! I have indicators that work properly. It was just a busted relay.
https://www.facebook.com/ProjectRustyquattro/videos/1106482282785400/
That box of bits has already proved its worth by giving me reliable window switches.
20785974_1106482962785332_86120052685141
Garage helper. Now I have dog and cat paw prints on my car.
20746160_1106483266118635_27617876844586
20728942_1106483296118632_92225778937743
I've been putting off scraping all that nasty stuff from the back of my boot lid carpet. After two minutes I stuck the scraper into my finger. Time to call it a day.
20776379_1106484202785208_37470435856787
Still Epic, and you've the patience of a saint :cool:
While I'm waiting for my instrument cluster to come back I've started to think about the stereo. At some point in the past this car had a pretty serious stereo install - for its time - but when I got the car the speakers were falling apart and wiring was a mess so I ripped it all out. So I need to start from scratch wiring in a new stereo. I got an 80s Blaupunkt tape desk with the car, which I hope works!
20861653_1110942615672700_75277407139068
20863393_1110942612339367_56936960837344
20863271_1110943042339324_38543090281969
20819695_1110943119005983_26834445354780
I'm going to get component speakers for the front doors, and I'm planning to install the tweeters where the tiny factory dash speakers were. I have two speakers with holes drilled like this from the previous tweeter install, and two perfect ones so the design of tweeter I get depends on which I use. I might be able to retain one of the factory speakers just for the voice module when I get that working.
20914636_1110943949005900_56821433379107
I've ordered one of these Out of Sight Audio Bluetooth/amp units. I did a lot of searching around and this is the only unit I've found that does everything I want. Which is:
Preserve the factory tape deck so it looks and works as normal
Add Bluetooth music streaming
Provide an amp for my four new speakers
Be invisible in normal use
Provide an output for a second amp and sub when needed
http://www.outofsightaudio.com/mark-iii.html
20882176_1110946449005650_79193817874980
