Rob's Ur Quattro
Pulled out the vehicle speed sensor. I think it's busted. There was plenty of gunk and corrosion in the connector but the O-ring is broken on the sensor itself too.
22095813_1139853579448270_59468168910736
22042282_1139853576114937_74525494606124
  • Replies 1.7k
  • Views 177.9k
  • Went to the supermarket while I waited for traffic to die down a bit. Second supermarket car park of the evening. Terrible pic, it was getting dark The drive home was uneventful. L
  • RobClubley
    RobClubley
    Back on its wheels at last!
  • Wento for a quick trip to the petrol station. Got sidetracked. I am loving this car! It sounds like it's gargling on the fuel not just drinking it, what an awesome sound!
Ooh, ooh, ooh, well, I pulled the other half of the speed sensor out, the above was only half of it! I cleaned it all up more, clicked it together properly and screwed it back in place after testing that the drive part on the driveshaft worked.
22045931_1140020489431579_52288895403889
And it works! Managed 6kph on my drive :D
Better book a WOF then, see what happens!!
Pretty sure my rear diff is locked and the control isn't working so that's another thing to fix.
Made a clean bit. Testing a few last things before first WOF. Number plate lights didn't work. I'm sure I tested them before. Both bulbs were toast anyway so that's now sorted.
So I booked it in for tomorrow morning. Gulp...
22254846_1145738472193114_17945867206171
Fingers crossed.
WOF Time....
22228545_1146322978801330_30382001072135
Failed :D As expected really.
22279927_1146325032134458_72350116669541
Rust on the sill - expected that.
Steering play
Top mounts not sitting properly
Exhaust hitting driveshaft (expected that too)
Steering rod hitting things it shouldn't (it's the LHD one, I thought it fit. bugger)
Also the speedo stopped working again on the way back.
22218545_1146327082134253_23035428465437
22254741_1146327085467586_27675041782574
22256437_1146327088800919_35487892440569
Sorry for the wobbly cam, the mount I used was not good for this job!! Thought I'd upload this anyway for the 5 cylinder noises :)
That's good work Rob, the list isn't that long.
shouldn't take too long to fix.
Dirty car:
22405688_1152344838199144_11761824331953
Tie rod had returned from HBI Engineering and looks like new.
22496121_1154780981288863_24493904607583
Should be able to get it fitted tonight, tweak the exhaust then get the car back on its wheels again.
Haven't had a lot of time to work on Rusty this weekend but it's back on its wheels with working steering. Plus I picked up this little gadget as the battery seems to be draining itself far too quickly. Might be a worn out battery or something draining it, not sure yet. You can Bluetootth to it from a phone to monitor battery charge.
22552887_1158528344247460_17691438012178
22712385_1158528350914126_36952906040148
22555321_1158528347580793_67961762218670
22687540_1158528414247453_38566907048765
22729075_1158528410914120_23120860474112
22688749_1158528407580787_60791320493316
That's a nice bit of kit
Picked this up from VW. Hoping it will be adaptable to make my speedo work again.
22829165_1160797970687164_47696686887037
22770873_1160798084020486_42952970255523
Hard to tell from OEM
Hopefully it works. Test drive on Monday!
22829891_1162346137199014_81817121451930
As for the battery - it's drawing 0.04-0.06 amps at standby, and in five minutes where all I did was unlock and lock the car a couple of times, test the boot light, and run the interior light it went from 41% to 26% charged. Time for a new one I think!
A little bit more convincing...
22792382_1162523307181297_42026548800246
Slightly improved weight distribution due to whopping big new battery. Need to work out a way of strapping it down.
22904555_1162538997179728_26694191368240
i spent ages going around various Super Cheaps and Repcos trying to find a battery with terminals the same way as my existing one then realised when I got home that all I would have needed to do was flip it around and the wires would have reached. What a muppet.
On my way out to get the rusty sill checked out.
22904825_1163894713710823_12339838813172
22859986_1163893540377607_80381513607049
80's goodness
22853001_1163892450377716_60381987053595
So the speedo repair didn't work, read zero the whole time. Need to investigate that more.
I've booked the car in for rust repair soon, plus a wheel alignment and re-bleed of the brakes this Saturday. The brakes are really spongy and I've bled them twice. WIll get a pro to do them :D
There seems to be an issue with idling once warmed up, revs drop way down and the car stalls.
Other than that it feels so good to drive it! It makes an amazing noise, steering feels good, it makes me grin :D
Looking good Rob,.
who's is the DeLorean in the background, can't be many of those in NZ?
14 minutes ago, mdk1 said:
Looking good Rob,.
It was in at my mate's detailing company for a clean up for sale. You clean them with a scouring pad!
It's original LHD in great condition. Not big inside though - I had a sit in it and my head was rubbing on the roof and I'm only 5'10".
The owner is apparently wanting $90k which seems a lot to me! About GBP 50k
Not bad if it has a working Flux capacitor and Mr Fusion on it though! ;)
Not sure what they go for here, these days?
Never really appealed to me really, film references aside :)
The suspension has settled a bit. Reckon my old car would pass the shoe test?
23154723_1167319543368340_46597797885421
Going in for wheel alignment, brakes bleeding and exhaust alignment.
I've bled the brakes twice and they're still spongy, time for a pro to do them. Exhaust alignment because them doing it on a ramp is much easier than me laying on my back under the car.
23275494_1167797569987204_13243430158156
Apparently the brakes work properly now!
Update on the list :D
23270259_1168803646553263_19658800314237
Wheel alignment done, brakes bled, exhaust adjusted but still knocking when lifting off the throttle. Next: rusty sill and working Speedo.
23270557_1170042936429334_13285874028199
Hes come a long long way from when you saved him Rob :thumbup:
The speakers were just a few mm too deep to fit properly in the holes and it bothered me that they didn't sit right to I got some thin spacers to push them out a bit. Abtec Audio Lounge made them for me while I waited. Great service!
23473101_1174442409322720_34478062669639
