Rob's Ur Quattro
The last part of my plan is this, to enable me to change tracks and volume without looking at my phone.
20882079_1110949822338646_43883208154883
  • Replies 1.7k
  • Views 177.9k
  • Went to the supermarket while I waited for traffic to die down a bit. Second supermarket car park of the evening. Terrible pic, it was getting dark The drive home was uneventful. L
  • RobClubley
    RobClubley
    Back on its wheels at last!
  • Wento for a quick trip to the petrol station. Got sidetracked. I am loving this car! It sounds like it's gargling on the fuel not just drinking it, what an awesome sound!
It's easy enough to test car hifi as long as you have the units, their interchange wiring, and a 12v battery.
Finally I have the correct clutch reservoir. It just arrived from Greece!
20933954_1111333315633630_45875366397062
Starting to add stereo wires. Speakers first as they're the simplest.
20933891_1112260355540926_98375151555741
Oh and i fitted the wheel centre caps.
20901631_1112260808874214_41433691357627
Took Rusty out of the garage for the first time in months. The brakes work but are well squishy. Need to bleed them again.
It would have been rude not to do a quick video.
Two years ago vs. now. Progress is being made!!
20988434_1114182175348744_80733486364296
21055348_1115044165262545_85441528334515
Standard (top) vs. H&R springs.
20989034_1115179831915645_19948157061519
@RobClubley - All the other capacitors!? The paper film ones won't leak, only the oil-filled ones.
All the ones he advises :D I'm taking his advice as he knows what he's doing.
Hoping to have it done by next week, and that's pretty much all I need to go and get it tested for a Warrant of Fitness. :o
Well done Rob. It's been a long time coming.  Bet you can't wait to finally get it out on the Road.
That's ok then. I don't know which are which on that board, but I do know the 2 types and that paper film insulators don't tend to break.
I am so excited. Trying to contain it :D
He sent me a spreadsheet today with a list of which ones look iffy, original part number, specs, replacement part number. And he's noticed a resistor that looks like it has been very hot. ETA for parts is 7 days then it's go time :D
By then I should have the Bluetooth unit and all cables so I'll be able to finish that off and rebuild the dash, refit the ECU in the proper place (it's cable tied in now) and make it look nicer.
Though there is the voice synthesiser to sort out too. Hmm.
Cleaning up the trim that goes below the steering wheel and holds the ECU. There are holes drilled in the underneath where presumably a car phone was once fitted. Seems like a good place to install my bass controller knob. I'm still not sure if I'll install a sub, but it's easier to install the wiring now.
21200678_1121362824630679_76289922051247
Then I realised I installed the bass knob in the wrong piece. Not sure how I ended up with three different ones! This is the correct one.
21246474_1122646941168934_87422807371083
21192992_1122646991168929_40971947002911
Bought some contact adhesive and refitted the rest of the boot carpet.
21192552_1122648394502122_89278189367753
21270891_1122648451168783_40557607372700
21248431_1122648481168780_14470777270144
21272838_1122648511168777_20637563429007
21246392_1122648557835439_54867929913641
There's foam around the edges of the glass vacuum tube displays in the dash to keep dust out, which had turned into a sticky mess. This was my solution.
21318922_1122886734478288_32890122428220
21248276_1122886831144945_73308682527908
21200823_1122886791144949_83329078875581
Re-fitted the back seat. So I had to try it out.
21246539_1122887877811507_36636073289658
21316251_1122887871144841_90908277011985
My car texts me now! GPS tracker is working.
21371036_1122906547809640_34210433283604
I've been putting it off, but it's time to try and sort out the voice unit.
21248448_1123597867740508_60946491506317
These should not have been connected. They were!
If connected they bypass/disable the voice unit.
21314391_1123597947740500_86490256186083
Some #$%^#% has pulled out the pin for the speaker.
21316432_1123597997740495_23753779658701
Test rig. Nothing happening.
21231074_1123598044407157_74832786058617
Looking less complete than it was. Hmph.
21273686_1123598067740488_59194747181151
Pretty sure that's not the factory connection for the throttle cable.
21432895_1127656710667957_26379475902050
21463403_1127656880667940_43488369296046
21427148_1127656914001270_41503761962881
Many thanks to Neill for sharing his technical information like this.
Started on the Out of Sight Audio install. Then realised my battery was flat, too much playing with stuff without running the engine to charge the battery.
21752719_1129318737168421_18677846514630
Finally got these so I was able to get the rear speakers in properly and add the insulating cover to the battery live terminal.
21743582_1132007630232865_32351100437566
21731667_1132007676899527_22818560141806
21731509_1132007753566186_80046780502609
And the Out of Sight Audio is working! Still waiting on a couple of wires for the tape deck, and my front speakers next week. Then just need to re-bleed the brakes and it's WOF time.
My front speakers have arrived. There's something very exciting about shiny new speakers.
21762382_1135357943231167_45214843051049
21640913_1135357996564495_81528049278062
Started on the install. I used my original speakers to mount the tweeters which already had holes drilled in them from a previous install. Not happy with it like this though, especially the passenger side.
21765801_1135775359856092_74969892738945
21687042_1135775406522754_64469896054482
21762624_1135775426522752_94488129099478
21762827_1135775483189413_42593820319756
I think my speakers sound good - but my Bluetooth thing is making a very annoying high-pitched buzzing which I need to sort out.
Tape deck appears to be non-functional :(
Patricia talked to me!
https://www.youtube.com/watch?v=AahImc-viUc
But then refused to talk again, dammit.
Got my throttle link bushes.
21688368_1136705926429702_10144861191774
21765425_1136705969763031_56129684691342
21762527_1136705996429695_42550848502023
21993061_1136706033096358_66561847716088
And the dash is all back together.
21762558_1136706376429657_16583011555216
21762659_1136706426429652_15826552774684
21762633_1136706456429649_48070531965562
21765364_1136706486429646_21346475491401
To-do list is looking better :D
21764738_1136768929756735_61403997983046
Bleeding the brakes again. Found two slow leaks on the right side of the car - might explain the squashy pedal.
21949920_1137407323026229_33953711162135
Went for a drive around the block. Nothing fell off. Nobody died. Though there were some interesting suspension clunks when entering the angled drive. And the speedo worked for a second then read zero the whole time. Brakes were not great but improving as I went, so starting to bed in I guess. It was very loud! The wife said she heard the whole thing from inside the house.
21949801_1137409496359345_52513778936782
21768830_1137409493026012_89487828528880
