Rob's Ur Quattro
The front subframe is in! With a little help from my Mrs.
18156164_1020696578030638_12273875670039
18121383_1020696618030634_58344325891721
17991969_1020696608030635_90189025086213
Edited by RobClubley
  • Replies 1.7k
  • Views 175.2k
  • Went to the supermarket while I waited for traffic to die down a bit. Second supermarket car park of the evening. Terrible pic, it was getting dark The drive home was uneventful. L
  • RobClubley
    RobClubley
    Back on its wheels at last!
  • Wento for a quick trip to the petrol station. Got sidetracked. I am loving this car! It sounds like it's gargling on the fuel not just drinking it, what an awesome sound!
Yay!
18119161_1021423367957959_78929936659254
Very pleasing!
If you're anything like me, you'll be dying to spend every hour of every day on it now it's so close to being done....then you come across a problem and wished you'd never started! Keep up the good work, the end's in sight!
Yep!
So many more jobs to do. Cleaning stuff, for a start. And torquing up bolts, and adding fluids, and removing the bumpers to add some missing seals and clips, etc etc.
Excitement...followed by disappointment. I bought the wrong brake pads. Fail.
18155789_1023444341089195_57756020990303
18156658_1023444394422523_47457442341132
18157453_1023444614422501_49469925943889
18157086_1023444667755829_64274188353847
Rear subframe and struts are in.
18192664_1024020287698267_58032050103740
18193800_1024020351031594_33420268337755
18199250_1024020407698255_48184848275923
18157902_1024020511031578_52846523337728
Took the brake dust shields off the GT rear beam. I was hoping to use them but they're quite different.
18278689_1025482877552008_42818332957387
18238230_1025482910885338_53597520520875
So I ordered a pair of new ones manufactured by Quattro Corner in the UK.
I also finally gave in and ordered a few things from Audi Tradition. Waiting for the call to pay duty on that stuff.
These look more like it! Thanks to speed.co.nz for getting them to me super quickly.
18278356_1028976403869322_63555746887472
Brand new stainless steel brake dust shields for the rear, from Quattro Corner. The quality is excellent.
18449501_1036560866444209_52518312256169
Bit better than these:
17917675_1036564649777164_30392583886562
Got home to more presents. A box from Audi Tradition.
18558968_1036704086429887_87712066960964
Shiny new parts to bolt onto an old car are the best thing EVER!
We have back brakes!
The lines seem a bit tight but they're slightly longer than the originals. Flexis are just test fitted for now.
18449528_1037850512981911_30355509680105
18486190_1037850562981906_17461910877946
Looking good Rob, coming together nicely now. :)
Bit of progress this weekend.
Connected up the brake lines, torqued up the front driveshaft bolts, repaired and fitted the rear left driveshaft, broke off the corroded shielding on the ABS sensors, re-wrapped and re-fitted them, replaced a broken wire to the rear diff, not sure what it does (yet), looked at a few other things and pondered them :D
I thought I'd better clean this out..
18767370_1045180062248956_89220403670327
Yay, got this nut back on. I damaged it trying to get it out of the hub.
18700388_1045181182248844_28088550657201
And it's in
18814976_1045181592248803_46434111278915
Brake lines are all complete. No fluid in there yet.
18671009_1045182155582080_36245072936257
Ticked a few things off the list but I keep adding more.
18740446_1045182438915385_57461768325276
The damaged fuel line and the replacement I bought from Audi tradition. Not sure that's the right one
18700615_1045182915582004_71476946542957
I'm itching to clean it. Need to wait until Final Touch Wellington to do it properly.
18766742_1045185495581746_88513743169513
18739168_1045185688915060_17446688378349
I think quattros all had an electrically locking rear diff.
Edited by KenONeill
The centre and rear diff locks are vacuum operated, by a rotary knob. But there might be some sort of electronic actuator involved as well. Need to do some reading, I have some manuals that I've only scanned through.
It's connected to a feed from the front of the car and an earth so it's not a sensor.
That's awesome. I wish I had the time, money and patience to do it to that level.
Last night I decided to put some brake fluid in mine. Got the master cylinder and bias valve bled then went to do the right rear and fluid started leaking from the left rear. I hadn't crimped it properly and it hadn't sealed. So I ended up cutting the end off the hard line and re-crimping it while brake fluid dripped out all over my hands and tools. Got it to seal and did the other side but now I can't get any fluid out of the rear left caliper so I think I may have managed to seal it completely somehow!!
By this time it was 10pm and I was over it so will re-visit that one.
Modify message
Finished bleeding the brakes. Need to do it one more time with an assistant to double check.
Also filled up the coolant and power steering fluid.
18837071_1050866918346937_70626115396038
Fitted the new fuel tank to pump hose. Doing it like this seems to make sense and I didn't need to cut it. Need to sort out the clips and stuff to make them better.
18951015_1050898535010442_48523529798110
I couldn't resist...
18891486_1051751751591787_64398829414484
Also got the handbrake connected up last night. That was a bit fiddly.
I'm getting there bit by bit!!
Just bit the bullet and ordered a Milltek exhaust through NZ Performance Tuning.
Don't forget to tighten all of your hose clamps.
18953218_1054082651358697_28099400591542
I borrowed some big boy tools from my mate. Got the hub nuts tightened in two minutes.
18953560_1054754411291521_32772170948192
Put 4l of petrol in. None leaked :D
Just need to double check the brake bleeding and I can put the wheels back on.
19023519_1055388094561486_79870707029429
Attached some wheels. Still have tiny bubbles in the brake fluid when I bleed the front left. Need to sort that!
19024934_1055388614561434_45169628351396
19029576_1055388597894769_13190081558534
19143229_1055388611228101_85846149988595
Oh and I've misplaced my locking wheel nut key. Sigh.
