Rob's Ur Quattro
You know what Rusty is missing?
Well, a few things but one big one is some doof doof noises. And of course something to make them work, as the Out of Sight Audio device is winging its way back to the US because of a loud hissing noise problem.
Anyway I happen to have a rather nice 10" sub in my garage which I want to install somewhere. Of course anything like this must be reversible, so I got the spare side trim out, from the GT donor car, to work out how it might fit.
There's a big space inside those lovely box flares which really wants to be a bass box :)
23467018_1174972442603050_62413330511735
23467394_1174972792603015_62691649513620
23511151_1174972775936350_45420541986349
23456443_1174972772603017_61963469453704
23592302_1174972945936333_27005147070766
23467482_1174972935936334_59191494364956
23550958_1174972942603000_49118150133658
23550013_1174972989269662_38972770642892
  • Replies 1.7k
  • Views 177.9k
  • Went to the supermarket while I waited for traffic to die down a bit. Second supermarket car park of the evening. Terrible pic, it was getting dark The drive home was uneventful. L
  • RobClubley
    RobClubley
    Back on its wheels at last!
  • Wento for a quick trip to the petrol station. Got sidetracked. I am loving this car! It sounds like it's gargling on the fuel not just drinking it, what an awesome sound!
Do you really need any doof doof noises with the sound of that stunning engine tone?
Well... no. But why not have both?
I did a bit more playing with the sub tonight. I looked into doing a fibreglass enclosure but I really don't want to get into that much mess, fumes and time! So:
Step one - make a CAD template (Cardboard Aided Design, thanks Project Binky!)
23593393_1175987025834925_86204443880909
Step 2, cut a piece of leftover MDF to shape.
23632377_1175987032501591_82005312888586
23467394_1175987029168258_27347352403285
23471933_1175987095834918_62613301620640
Step 3, make a hole in the spare trim piece.
23471940_1175987102501584_15493429077976
23549955_1175987109168250_78669815918061
Step 4 - test fit the sub. It fits well, plenty of room.
23549964_1175987192501575_22595557697847
I'm planning to keep it simple, bolt the MDF to the bodywork, fit the trim over the top then screw the sub in place.
See what it sounds like! If it's not right it'll be plan B
Next step after that is to get some thin ply and use it to strengthen the trim, then find some vinyl and leather to try and match the existing stuff.
Sneaky school run on the way for more rust repair.
23509185_1176423392457955_44778964919124
23550129_1176423425791285_14234966705559
23593634_1176423485791279_63165784545861
That looks so cool, I'm not jealous at all :giggle:
Top stuff so far Rob
Just wait - in two weeks it goes for a full paint correction and ceramic coat. It's going to look epic. Then I'll need to clean it :D
What coating brand are you going for Rob?.
Did a bit more tinkering with the spare side panel to work towards get the sub fitted. I bought some thin ply to strengthen the panel so I can line it - couldn't find red leather but I got some vinyl which I think will look okay. We'll see if it does!
I used contact adhesive to bond the two wood surfaces together. The scrap metal pile came in handy to  weigh it down.
23737745_1182537281846566_19548512149341
23735956_1182537275179900_57731685595585
23735958_1182537278513233_16598529176526
23736274_1182537368513224_30663548570163
23800202_1182537371846557_13215696362992
Looks promising.
23783615_1183763458390615_45700599392604
Got another speed sensor.
23755291_1183289785104649_70375883579725
It's the same shape as the Audi one but same connector as the VW one!!
23916461_1183762881724006_83762577336220
Will have a play at the weekend.
Just collected the car from Kohl after getting the last of the rust repaired, and a battery clamp made. Pics later :D
The battery clamp that Kohl Rod & Custom Ltd made for me. Great job, very neat.
23916361_1184972374936390_89273091755579
Fitted the new speed sensor but couldn't be bothered to move the wife's car out of the way to test.
So I spent half an hour trying and failing to get the centre rubber exhaust mount on properly, eventually leaving a cable tie on there which won't last long but might hold it until I can have another go when the car's on a ramp.
I did a bit more on fitting the subwoofer today. Test fitted the panels, and spent lots of time lining it up, trimming the MDF piece, making a metal bracket, bolting it in, realising it didn't line up, adding another MDF ring as a spacer and finally covering the trim in red vinyl.
23826204_1184976491602645_45206212281119
23847097_1184976488269312_25939804146861
23926390_1184976484935979_47996185068515
23847287_1184976551602639_62004989434536
23916650_1184976544935973_66618093629494
Pretty pleased with this. Just needs the grille fitting now.
23826319_1185527464880881_54242579199924
23825884_1185527518214209_63095238101876
23826248_1185527561547538_74438316862567
Don't know how this happened, just old age I guess, and sun damage making it brittle. Ah well, time to break out the old heavyweight shift knob I had in the Skoda.
23845759_1185589558208005_37706453335788
23843393_1185589568208004_82091638220886
Got the water blaster out and gave Rusty a quick rinse. Only a week to go until Finer Details NZ do their stuff, can't wait!
23826363_1185596214874006_38227728581015
24059297_1185596218207339_42144093578219
24129657_1185596208207340_77645347123963
23843510_1185596291540665_88243168752783
23916621_1185596288207332_33360801168653
More fiddling with the speed sensors today. The factory one works and produces a 5v pulse as expected. The two VW ones do not! Unless the pins are in a totally different order and I wired them wrong, they don't seem to produce the same outputs. I continuity tested the wiring to the dash - all good. So the fault is either the dash itself, or the connector on the factory sensor, which I have now replaced with some spade connectors
Next step - test drive. Can't do it now as I'll wake my daughter up :D
This is the shape of the passenger side under-dash panel I'm missing.
Thanks Takas for bringing yours round, much appreciated.
23926536_1187597494673878_83544184048943
Another sneaky school run in Rusty
You can tell where I went by following the trail of oil drops
24059634_10155715139540977_8074783080328
No speedo on the way there. Working speedo on the way back!! As soon as the car starts to warm up, oil starts leaking, possibly from the dipstick, hard to tell. Need to sort that out though.
24059536_1188159011284393_48603185633015
Amp is mostly in place. Need a fuse and a longer power cable.
24130211_1188632851237009_62044713269133
Looks like the oil leak culprit. I tightened it a little bit. Not sure if that will do the trick or it needs to be replaced.
24131267_1188638441236450_89729762591710
Also I can't resist taking pics of Rusty.
24130438_1188637257903235_51248808806857
24130323_1188637287903232_44275523648784
24131986_1188637294569898_45007134662639
24059730_1188637307903230_36127928966731
@RobClubley - Oil leaking from the dipstick tube suggests the sump is pressuring to me. Can you legally replace a Positive Crankcase Ventilation system with a catch can on a 1985 car in NZ?
Looks like it's the oil pressure switch actually leaking. I tightened it a bit, and have ordered a new one.
Yep that's a broken cable from inside the seat. The one that lets the seat fold forward. I wonder sometimes if this car is actively fighting me.
24232642_1189528997814061_27888585955021
If the leak was from the thread you've probably got it already then. I've also fixed one of these with some PTFE tape on the threads.
Thank you so much to John Stone for sending me these. The manual was a huge unexpected bonus and I'm really grateful for it.
24232660_1190400887726872_79531409137960
WoF re-test called off due to intermittent speedo.
Also I need to fix the stalling at idle.
24297477_1191012790999015_58636874043657
Edited by RobClubley
It's time for the long awaited clean! Dropped Rusty off today at Finer Details NZ. Imagine how good it'll look after several days of attention from a pro detailer, plus a ceramic coating. So excited to see the results!
24254905_1191390894294538_88919505536211
I just realised when I pick it up I can get the pinstripes on and the rear badges. And the door rings.
Hey Rob,
I've been out of the loop for a while, last time I dropped by here rusty was still off the road.
It's great to see you have persevered and Rusty is roaming in the wild again.
6 hours ago, mannyo said:
Hey Rob,
Thanks :) It's not quite officially on the road but I have snuck in a couple of sneaky test drive/school runs.
Need to get the oil leak fixed and speedo reliable, and it should pass the WoF (MOT)
