Would Adblue put you off another diesel
Would AdBlue put you off buying a diesel? 152 members have voted
  1. 1. Would AdBlue put you off buying a diesel?
Please sign in or register to vote in this poll.
If it was 0% as well then it would be a deal worth considering but as it's not then it's probably cheaper with 0% when that was available and buying the extra 2 years warranty.
As you say it's just marketing, especially as the small print says that its for stock cars only sold by the end of the month.
So in the scheme of things no change.
Edited by VAGCF
  • Replies 281
  • Views 41.8k
  • AdBlue is there to counter the increased NOX from the DPF Every time they add another system, its generally been to counter the new problem from the last 'emissions enhancement'. EGRs produce extra s
  • The problem with this is most people prefer the real world driving experience of diesel over petrol... :|
  • Gently, Graham, gently....  This was the OP's first post and he hasn't had time to get used to the...errrm...format.  I'm sure you just overlooked that   We must remember that the membership here i
But the all new model might be covered for 5 because of VW's greater confidence in its reliability ....otherwise surely the question is why not
They must be lacking a bit of confidence in the New Kodiaq then until they see how it goes.
The Octavia & Fabia Face Lift Models should come with longer warranties in Europe as all snagging faults should now be ironed out and they will know how many Warranty Claims they have had up to now.
  • 4 months later...
I've been looking at the 2017 Australian Tiguan's specs which, strangely, refers to SCR
AND
EGR as being part of it's emissions controls
There is no mention of any Euro standard it meets.
Euro6 is mandatory here from July, so it this sloppy editing or a transition model of some sort?.
Proberly all the reject engines they've salvaged for the United States!
SCR equipped vehicles still use EGR coolers.
Indeed.  SCR just means you have to use less exhaust flow through the EGR circuits than you would without it.
AND
Just when we're thankfully getting out, it looks like they are trying to expand their empire to the other side of the world!  Is that the thin end of the wedge?
AND
The new 2.0 Merc diesel uses two water cooled EGR's, CAT, DPF, pre Adblue mix chamber and much enlarged SCR. It's expensive tech, hurts economy and will use more adblue
The new Euro real world tests that have a range of temperatures and loads that require a range of technologies.
And is the reason why many manufacturers are saying that small to medium cars and small vans will be diesel free within 2 model generations. They just wont make financial sense.
Lee
Edited by logiclee
It intrigues me that they make no mention in the Australian specs of meeting any standard but they do in the U.K. one.
I wonder if they have reduced the capacity of the EGR's cooler also, due to there being a cleaner burn, and thus a lifespan no better than the old version.
I might now just hang on for a BEV with serious range.
I notice how much easier and cheaper it is to access a Mercedes EGR valve compared to E-W engines also.
I wonder where they put it in the A and B series.
Have moved back to petrol!!!
Fred
Fred
Agee, if you don't do massive mileage or tow a LOT the figures just don't add up for me.
So what does it achieve that post combustion AdBlue treatment doesn't do?.
Is it involved in control of blowby gasses?.
Reduces the amount of NOx created in the combustion chambers.  Prevention better than cure, kinda thing.
Reading about the supposed advantages of SCR, it seems to say that the combustion process (temperature) isn't compromised and thus the higher temps mean less particulates to deal with, higher power and reduced consumption and CO2 emissions.
The significantly higher NOx produced from the higher combustion temperature is dealt with by the AdBlue ....I thought.
Not enough I guess.
Great, but do you want a huge adblue tank?
Only if it means the buried EGR cooler valve doesn't end up costing thousands to fix.
Are you sure, I was led to believe cars were equipped with one technology or the other?
If you go back to the pics of the Tiguan emissions specs it mentions both, which has me thoroughly confused as to the reason.
Nobody has an answer as to WHY.
Am I nobody? Or do you just not believe me?
This document suggests that some euro6 vehicles do have both;
Quote
The majority of manufacturers have adopted the SCR route to comply with Euro 6 standards, either solely using this technology or in combination with EGR
http://www.arvalfleettoolbox.co.uk/media/6120/euro-6-guide.pdf
Huh?
Neither.
I just want to know why there seems to be a duplication in the method of controlling NOx emissions.
Egr reduces the need for post-treatment, so that the SCR reactor/catalytic converter doesn't need to be enormous, and adblue usage doesn't have to be matchingly rapid.
I thought I'd already said that, more or less?
The scene:
Sit down
Sign here
Don't ask questions
Take what you're given
Be grateful
(wood duck)
we know nothing
