VCDS options on Superb III
Buy a genuine cable and it will all work.
  • Replies 2.5k
  • Views 826.8k
  • if anyone is interested, below is a PDF I created of the various code changes I've made to my Superb (MY17) over the years. whilst some instructions r done with VCDS, and others with OBDEleven, t
  • I'm aware the mod for 30 colour pallet in the ambient lighting screen has been mentioned several times on the forum. TLDR: The RGB values used on available in the table at the bottom on my post.
  • Not sure how that would work, by your reconning they would have less need for rear DRL's as they have less daylight hours.   Brake lights are 4 times brighter than a sidelight / rear DRL, th
Hello,
Have someone coded dynamic turn signals on Skoda Superb III Non facelift model. I have tried something but its not working, chat gpt says maybe it can be coded.
Lool, interesting that people are playing with their cars according to info from ChatGPT.
Well, hopefully you will stay with the lights and not go into ABS module or something. Because that could be much more damaging, maybe even leathal.
And no, you cannot code them. (not from a smart ChatGPT, but only a normal dumb person).
Edited by mtl
Ok. Thanks
Edited by Emird
Yeah… in one moment it went wrong😂
You think that there is no chance to code because its led strip idk…
If you want to waste other people time, just go talk with ChatGPT. If not, read my answer again. And again. And again.
9 hours ago, Emird said:
no it is not the original cable. it is clone. could that be the problem? it opens other modules. when i enter the security code it accepts it properly.
There's ur problem!! Fix that then ask for help.
I know it's expensive, but get a genuine cable if u want to do things properly and don't want issues.
Alternatively, get an OBDEleven.
Early mk3 Superb models (M15 & MY16) used an older setup which used to have coding in the 09 module, as well as a few others.
From MY17, they changed things, resulting in the use of adaptations and putting 0s in coding.
Hello, yes of course that is very clear.
Thank you very much for helping me understand that the problem is with the cable. I returned the cable and am looking for a new one.
Dynamic indicators is "Rollenblinken" in Stg 09.
You are coding your side lights - SL.
Edited by 26DIPP
With a MY19 Kodiaq, I can't remember if the rear blinkers are splitted on both the boot and the rear wings.
If they are, then all what you may be able to do (with a genuine cable 😉) is to activate rear blinkers in opposite phases for both parts on each side.
I've no idea of how to do it, but I remember I've seen this on a Golf Mk6 or Mk7 on YouTube.
May be someone played with a Superb Mk3 estate too and set this mode but using tail lights as blinkers as in the US. But I don't think it is street legal in Europe (whatever the country).
On 11/09/2021 at 14:42, Gizmo said:
09
Access permission: 31347
Adaptation
Leuchte16BLK SLB35BLK SL KC9 (Front left eyelashes)
Light function C16
put on "Daytime running lights"
Dimming value CD 16
Put on "100"
Leuchte17TFL RLK SRB3TFL R BLK SR KC3 (Front right eyelashes)
Light function C17
Put on "Daytime running lights"
Dimming value CD 17
Put on "100"
This encoding will work only for the vehicles which already shine "Eyelashes" in light by the work have. If no lashes out at the park light light, the corresponding lamps are not installed.
That you can easily check if they are installed:
Is available in the channel
Light 16BLK SLB35BLK SL KC9
Light function A16
"Inactive" in it, then the eyelashes are not installed.
Hi Gizmo, you seem to be the guy to ask my question after reading various hours of posts. I have my US lights activated on my 2019 sportline but i've been searching for hours to also activate my side turn signals (the ones in my mirrors). As far as i could find there is no channel for them under 'leuchte'? Any experience on this? Thanks in advance for your feedback.
Are the mirror indicators not controlled by the door control module?
It depends on which indicators you’re talking about.
I don’t know about blinkers, but BSD lights are controlled by 3C Lane change control unit for instance.
On 14/02/2023 at 23:00, Agustnr said:
Yes.
i,ve been looking in there to but did not find anything about the mirror blinkers. in 09 central electronics i can find all about the lightning, front blinkers, rear blinkers etc but nothing on the side blinkers unfortunately.
1 hour ago, Bap33 said:
hi, yeah i looked in there to but nothing on the blinkers in the mirror
Maybe in control unit 09?
Hello, I am interested to know if it is possible to code the ACC (Adaptive Cruise Control) so that it does not enter standby mode. My car is a Skoda Superb 2018. If anyone has done such a modification or knows if this can be done with VCDS, please share information.
Thank you in advance!
been looking there and i can find every light except the mirror blinkers 😅
This a screen shot from ODIS in Stg 42, driver door controller. Turn signal repeater is what you are looking for, but you can not modify it like other lights in Stg 09.
Indeed i found this but can only put this active or inactive. However its strange there is nothing in 09 referring to this light?
my mk 3 acc had a red triangle on the dash acc not working took off the radar cover went to arnold clark ordered a new bracket it cost me 48 pounds for the repair kit for the acc i picked it up today looked on utube how to replace and fix it took the acc device out disconnected it removed the twisted housing for the acc two screws holding it in and fitted the new bracket and refitted the acc device the red triangle was still there drove the car most of the day used the stick on the stearing wheel for cruise control and now the fault has cleared no recalibrating the new bracked holder has cleared the fault
Interesting that no recalibration was needed.
The Auto Hold function has been integrated into the HMI...
On 11/08/2025 at 04:40, Cairus said:
What is the coding for this?
