VCDS options on Superb III
Aight, thanks!
  • Replies 2.5k
  • Views 827k
  • if anyone is interested, below is a PDF I created of the various code changes I've made to my Superb (MY17) over the years. whilst some instructions r done with VCDS, and others with OBDEleven, t
  • I'm aware the mod for 30 colour pallet in the ambient lighting screen has been mentioned several times on the forum. TLDR: The RGB values used on available in the table at the bottom on my post.
  • Not sure how that would work, by your reconning they would have less need for rear DRL's as they have less daylight hours.   Brake lights are 4 times brighter than a sidelight / rear DRL, th
TSR coding (VCDS needed)
Perfect, I hope that those data helped a bit.
One more question: do you have speed limits from TSR also on Columbus?
Yes Igor, between yours, Alex's (factory supplied TSR) and my coding I narrowed down what coding was required.
Gizmo, perfect!
I have next step for You - code the possibility to close rear lid by the button from inside.
I do not intend to give up on the coding for that, Ross-Tech have a few different scans and admaps now so hopefully it will not be too long??
Works like a charm.
Thanks!
Still wont accept coding! a scan reveals the following errors:
5F - Information Electr.--Status:Malfunction 0010
Address 5F:Information Electr. (J794) Labels:3V0-J35-MIB-HGH2.clb
Can you post a full scan so we can see your long coding.
I remember hearing once that the rain sensor is engaged even when the car is locked and switched off?
Does anybody know if this feature from the Mk2 made its way over? Or will it need coding in?
https://youtu.be/3uxgL-x0dC4
It does not work on Superb 3.
I vaguely remember seeing somewhere a display ( may not have been on a Columbus ) that showed info like G and acceleration.....
a) Did I imaging this ?
b ) Is it possible to activate it ?
c) Is their anything I can activate on my pretty standard SE L or am I forever going to feel like a 2nd class citizen ?
Edited by Nick_H
This is Performance Monitor and lap timer. 280HP version might have it from factory (this is yet to be confirmed), but Passat BiTDI 240HP has it and it looks like this:
Though the tweak to enable it on Superb is still in development...
Nice one ! That's it ! I can confirm the 280 does not have it from the factory :-(
To bad, yet another candy to add to differences between Passat and Superb :(.
Mmmm... Dunno about that for me personally. I don't like the look of the Passat so would have never purchased one anyway....
Ah, that's a shame :(
New version of VCDS is available and on first look it seems that they have translated a lot of German to English language and some new options are available in LCH menus. This was just a quick look up on our Superb - Style equipment.
If any one will report anything new please let us know. :)
Are you referring to 15.7.3?
This has been out a couple of weeks.
o really? - sorry I was busy in December so I notice yestarday and I thought that came in this week. :/
Yes, it is possible, but I can't remember where I saw it :(
As the video shows it definitely is possible :D :D :D . I am not faking videos.
CAN gateway
Byte 8, BIT 4
Edited by mtl
Is it possible to enable a fatique indicator? ("a cup" + "take a break")
Thanks!
