VCDS options on Superb III
Gizmo it's not pinned
  • Replies 2.5k
  • Views 827k
  • if anyone is interested, below is a PDF I created of the various code changes I've made to my Superb (MY17) over the years. whilst some instructions r done with VCDS, and others with OBDEleven, t
  • I'm aware the mod for 30 colour pallet in the ambient lighting screen has been mentioned several times on the forum. TLDR: The RGB values used on available in the table at the bottom on my post.
  • Not sure how that would work, by your reconning they would have less need for rear DRL's as they have less daylight hours.   Brake lights are 4 times brighter than a sidelight / rear DRL, th
It's not this thread that is pinned, it's the new thread in the link above.
Enabled no stop/start and heated seat memory today.
VCDS 15.7.3 just been released, is it safe to use yet?
Apparently so, although about the only thing I need to go into 5F for is the TSR... and the Octavia coding does not work.
I just tried to put traffic sign recognition on with VCDS (using Octavia 3 guide)
(63) traffic_sign_recognition_0x21     on Superb it reads:
(63) -Locked menu contents-FB_NAV_6
DO NOT PERFORM ANY CODINGS ON 5F CONTROLLER OR YOU WILL LOSE MENUES.
Read this: http://www.briskoda.net/forums/topic/374919-my16-mib2-coding/
And you are looking in the wrong part of the ad. channel structure.
Now that 15.7.3 seems to work  fine on 5F ... how did you code the TSR for the Superb?
TSR is what I wanted, hopefully some tech guy on here can find away to do it.
Read this: http://www.briskoda....16-mib2-coding/
I didn't, because all the Superbs that I have worked on already had it activated.
But I think that this is what you are looking for :):
(63)-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21,activated
(64)-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21_msg_bus,Databus extended
CONFIRMED WITH A CAR THAT I USED AS A ''VIRGIN'' and did not have TSR enabled ;): it had this 63 channel disabled.
Edited by mtl
Foglights as coming home lights (the DRL’s and SLA ‘eyelashes’ also light up  ;) )
Do you have any info on how this is done ?
(Sorry if I've missed it in this thread or the other one!)
Anyone tried to enable Lane Assist with the new version?
This is not working on my car, are you sure it's "(64) databus extended" as there are a few options in there, (63) is enabled
Edited by BurialConstant
If I would not be sure I would not have given this info. I tripple checked also with Passat with TSR from factory and it is correct.
Did you code also other needed stuff? This is not enough for TSR to be activated.
No I have only done (63) and (64), what is the other needed stuff please?
(64) was already Databus extended on my car,
With the Octavia coding all are accepted until:
Controller 17 (Instruments)
07 Coding
Byte 5
Bit 2 Enable - "Traffic Sign Recognition installed"
This is when I get:
Error: Dynamic Road Sign Display
Also there is no "Display end of speed limit symbol" under A5
Controller A5 (Front / front view camera)
16 - Security Access - enter 20103
10 - Adaptations
Select channel Display end of speed limit symbol
Change to activated
Pre any coding:
(63)-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21 not activated
(64)-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21_msg_bus Databus extended
07 Coding
Byte 5
This is when I get:
If I understand correctly it does not accept the coding? Did you log it with Ross-tech if they have some idea how to go past this?
I double checked with other cars that had TSR factory installed and all had this activated.
Pre any coding:
The same with my test car without TSR.
It accepted the coding, but gave the above error, there was nothing else under Instruments regarding TSR either.
Maps for 5F, 17 and A5 as well as scan have been sent to RT.
So the error was shown on the instrument cluster?
What error was seen with VCDS?
Which navi do you have? Amundsen or Columbus?
Yes the error is with 17 and also shows on the maxidot and Columbus
Friday,18,December,2015,19:42:09:22041
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
VCDS Version: 15.7.3.0
Data version: 20151216
www.Ross-Tech.com
VIN: TMBBJ9NP9G7029***   License Plate:
Mileage: 652   Repair Order:
                Address 17: Instruments       Labels: 5G0-920-XXX-17.clb
Control Module Part Number: 3V0 920 911     HW: 3V0 920 911
  Component and/or Version: KOMBI         305 6422
           Software Coding: 27A5011A7F84A600018B7A0B5001000000000000
            Work Shop Code: WSC 73430 031 00063
              ASAM Dataset: EV_DashBoardVDDMQBAB 009046 (SK48)
                       ROD: EV_DashBoardVDDMQBAB_SK25.rod
                      VCID: 6FE6664BB6CB154698-803A
1 Fault Found:
16777012 - Function Restricted due to Interrupted Communications
          U1110 00 [009] - -
          Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 20
                    Mileage: 1050 km
                    Date: 2015.12.18
                    Time: 19:40:48
TSR is now working  :mmm:
Full details to follow.
Gizmo, do have Columbus, Amundsen or Bolero?
Great news, sitting in the car trying to get it to work, guess I can go in to the family until you post details then :)
Edited by Selafiel
This is on a Columbus, it needs VCDS to make the changes BTW.
