My new red fabia vrs
I have APs fitted and they are very good. Good looking fab there
  • Replies 117
  • Views 13.9k
Small update for now - got some correct size tyres on the montreals now! 195/45/16 And the arch gap isn't as bad as before!
In the next couple of weeks there's going to be a few things happening to the little fabia...
Whiteline RARB.
Forge rear strut brace.
30mm spax lowering springs.
Wind deflectors.
Brand new drilled and grooved Discs all round aswell as pads and return springs for rears.
And also going to paint my calipers red.
Tidy motor mate needs dropped!!
cheers man, i've got 30mm lowering springs to go on...
My old fabia was dropped and caused me no end of **** so dont want that again!
Very nice car! Where did you get your smic and pipework from? Did it cost much, if you dont mind me asking :-)
Cheers man, I bought the SMIC 2nd hand from some guy for £30.. come off his Mk4 golf.
As for the pipework I had it all custom made at an exhaust place locally which didn't cost that much.
With all the silicone bends / Joins / pipework and SMIC all in all cost about £130 which is cheaper than replacing the standard intercooler alone!
Not for the faint hearted though... quite a bit of modifications to make to mount the intercooler!
Fog light removed for better airflow to the uprated SMIC
Edited by JamieFabia6Y
And fitted team heko Wind deflectors
Theres no sound on that [emoji12]
I can hear the noise, maybe your speakers are broke? :D
Maybe try turning your volume up? :)
Some pictures today of Jamies after a nice detail, sadly my two are abit more dirty :D
Edited by hutchysrs50
Coming along well, have you now only got 1 fog light in? :D
Must be taptalk [emoji23]
Yeah just one fog light now :D
They are overrated anyway haha
Welll, I reckon you should scrap that fog light and feed a pipe up to the air filter? ;)
I might have to look into that! Not sure if it will pass through in front or beside the battery though... Plus I've got a cold air feed already from the original air feed hole behind the grille so might stick with the easy option :)
Relocate the battery [emoji14] (not trying to give you more work, honest ;))
Sent from my SM-G920F using Tapatalk
Haha it sounds like a lot more work... Just for a cold air feed seems abit much :D
Update:
I decided to remove the Milltek back box rear section and have had a mufflerectomy and a cupra style tip welded on...
Looks and sounds amazing!
I personally prefer the oval in the rear bumper cut out to the twin Milltek pipes...
Lucky i love the milltek :P Here we come! :D
Mmmm something seems a little off with the rear badge.. :D
