What goes in here?
More importantly, why is it below minimum? When did you last check it?
Have a good look around the engine bay for telltale pinkish-white stains. Radiator thermoswitch, that bottom corner of the radiator  and the coolant flange on nearside end of engine head are probably hot favourites for leaky areas.
Little finger when you're trying to work out if your engine is still hooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooot
Top it up with water from the tap to the middle of the bottle.
That's your expansion bottle that holds the engines coolant.
G12/G13 is the coolant you mix with the water.
I'm 99.9% sure you're not supposed to add water, just the coolant. You can add a little water if you're desperate, but I'm sure it's a last-ditch thing.
