Water collecting under door
Mine booked in for next Tuesday to get the new seals - will let you know how it goes!
  • Replies 192
  • Views 59.3k
  • Looking at mine Original seals: no holes on outside of seal ---*---*--- ----------- Modified seals: the holes front and back line up ---*---*--- ---*---*--- New seals: the holes are offset. Tha
  • See x3 files attached 1 Outside of car showing the water run off 2 Outside of seal, note the holes are located near to the bottom of the seal (@ approx 5 O'Clock) 3 Inside of seal, note the holes a
  • Praise where praise is due, mentioned water ingress in the front doors to my dealer at the 2nd service yesterday, and they confirmed the fault and ordered both front door seals for replacement today.
Dealer replaced under warranty...just need some rain to see whether it has made a difference now!
Car was in for a service today (Henrys Skoda Glasgow) got them to have a look at the door seals. I was expecting the issue that others have experienced but to there credit they agreed to replace them under warranty only small issue is that they are on back order.
My my16 has no issue with the doors. The seals have holes in them along the bottom. Would anyone like a picture of these for reference?
Mine was a MY16 and didn't have them...the ones they replaced them with have the holes.
No more wet feet in the morning when I open the door!
Yes please. My car has to make its regular trip to dealer for more fettling so I would like to get new door seals ordered through them
Sorry for the delay, I even over exposed the shots to show up the holes! ;)
Mine too, 2016 Scout has the holes, only on the front doors though!!! Making me envious seeing your mud flaps :envy:
Good point, I never checked the rears!!
The flaps seem good. Need to fit them properly, I want to put some gloss black vinyl under them to cover the gaps! ;)
I only had the water collecting issue on the front doors though, so...
I have a MY14 car and have the seals as shown.
I have the same problem, reported them and there are no replacements, they only drilled something, even worse different on the left and the right doors.
And in the end,  I noticed, there is still water retention in the doors, maybe not high as before, but certain amount as well.
I presume new seals are maybe different, so drilling similar holes on older seals may not produce desired results.
:rain:  :rain:  :rain:  :rain:  :rain:
If your car is still under warranty, I would show them this thread and insist as there certainly are replacement/upgraded seals!
I haven't had any water issues from the doors since new so as far as I'm concerned these seals work. May be worth getting a part number??
Part numbers from earlier in this thread are:
5E0837697C
5E0837698C
The dealer gave me a copy of the worksheet for the warranty work they did on mine, so I will try and dig that out when I get home and confirm what they have on there.
I solved the problem with the driver's door on my SE by changing it for a vRS.
You messed up the part number? :D
Best "mistake" (cough cough) I've made in a while.
Lucky you when you can make 30k mistakes.
My new 2016 Octavia hatch dont have this problem, and it those have holes in the seals.
What I dont understand is why the holes should help?
On my car the sills is getting dirty way past the seals, so I'm wondering if the fix from Skoda is that the seals dont seal so good as it did before, and should........
Luck has nothing to do with it. Worked bl00dy hard since I left school. Now at an age when it's paying off.
Bought the vRS used at £17.5k, a year old. I added a few £££ to my SE in PX. Long gone are the days I'd buy new.
Edited by FlyingGecko
My best guess is that - especially when on a slope - rain water or heavy dew runs around the door gaps somewhere and ends up between the outer seal and the inner seal/door frame. The holes allow the water to drain out...without them, the water pools on the door sill between the seals.
Door seals replaced yesterday same as above. Will monitor and advise if I have further issues.
  • 2 months later...
Can anyone confirm that the correct part numbers are "B" or "C" please?
I confirm. Numbers "C"
5E0837697C
5E0837698C
I'm after  replacing seals in Limerick.
No more water under doors!!!   :happy:  :dance:  :dance:
Edited by Bandini
