Navigation Data Update available
^^^ Yes you simply start the process and wait for it to finish. It will pasue if you switch off the ignition and restartwhen you restart. Usually takes about 30 mins to complete.
  • Replies 215
  • Views 50.4k
  • New, 2019 maps here:   http://infotainment-cdn.skoda-auto.com/base/maps/HIGH12_P169_EU_2018_2019.zip
  • FelisBengalensis
    FelisBengalensis
    The process is very straightforward. Download file to a PC and once complete it will then extract to wherever you select, or an SD card. The process tells you whether or not it was successful. Once
  • It's called "Component Protection". The VIN is embedded in the infotainment and matched to the electronic embedded VIN of the vehicle. The main aim is to stop stolen units being reset, having new syst
It's now updating  fingers crossed  thank guys for the help
That's it 100% updated 3hrs to download 1.5 hrs to unzip to card and 30 to update happydays
Good morning,
Hope somebody might be able to offer some help as I'm having issue trying to download the new maps from my SD card with no luck, I've followed the excellent guide from page 8 as I'm using a Mac, below are a couple of pictures to see if i'm doing something wrong. When I press the update button in the car I just get the message below in the photo!!
Regards
Ashley
Another photo.
Here is another.
Regards
Ashley
I got the same but had missed a piece off did it no probs 2nd
Files look same as when I did it ,I used usb stick ,are u using memory card in adaptor? in nearly did that but went with usb stick in the end .
So the car car did finally stop searching for the update, but I then got the dreaded error message!
6 hours ago, virginracer said:
I'm using a Mac
Your issue is probably caused by the invisible files created by MacOS. These are files which have a period “.” as the first character.
The MIB units aren’t programmed to ignore them and that’s why it causes problems for Mac users.
There are utilities, both free and commercial, to clean any external device of these files when they’re ejected.
Alternatively you can insert your card or drive back into your Mac and open it in a window on the Desktop. Press Command-Shift-. (that’s the period key) to reveal the hidden files which will appear grey. Delete them in both root and the two folders, then pull the card or drive. You will get the message about the device not being properly ejected but if you did eject it normally it will rewrite the hidden files. Remember to press Command-Shift-. again when you’re done.
...Oops, I should have read page 8 first! I assume you’re using a cleaner utility already so the above may be irrelevant. I use BlueHarvest myself which cleans the external device even when it’s normally ejected and does everything in the background.
Edited by BillyJim
Is this my problem, if so what is needed to correct?
Regards
Ashley
No, that's not your problem. That file is correct.
Is the SD Card write-enabled when you plug it into your car? Judging by your photo the adaptor slider is in the write-enabled 'unlocked' position. The MIB unit will want to write a small file to the card but can only do this if the card is write-enabled.
If you're certain the card is really* devoid of 'invisible' MacOS system files then I would suggest using a different media (any 32GB+ SD or USB drive).
Your card name has a space character: "SKODA MAPS".  Try changing the name of the card so there's no space character by using the underscore "SKODA_MAPS".
* You can easily check this by inserting the card in your Mac with the the adaptor slide in the locked position, so the Mac can't write system files to it. Then use the Command-Shift-Period combination to check the entire card for hidden files.
If all else fails, PM me.
I've done 6 MIB2 map updates using a Mac and all without problems but I had previous knowledge of the possible problems when I had MDI on my Superb II where the invisible files would show up.
Invisible files is not just a Mac 'thing'. Windows also creates invisible files. The issue is lazy programming of the firmware where invisible Windows/DOS files have been catered for but not for the Mac OS.
I have done as suggested and removed a couple of files to the trash can, what is left is below in the picture. I'll now try again and report back tomorrow, thanks again for taking the time in trying to assist me.
Regards
Ashley448512520_Screenshot2019-12-19at23_11_30.thumb.png.80b8a3b3b4e3dec41a15546febb5d7e5.png
I'm currently just downloading the maps again from Skoda, I'll then do as suggested to see if thats my problem and i'll report back.
Kind regards
Ashley.
Update for you all, firstly many thanks to those who have taken time to try and assist me with this issue, unfortunately nothing has worked baring in mind I'm not very tech savy!
But I need to give a massive shout out to member rutterfordharvey who was extremely kind and sent me his SD card in the post, which worked without issue and took about 45 mins to download.
Kind regards
Ashley
