Hutchysrs50 - 8th Fabia... Special edition
Yep, definitely. Still braked perfectly well, no wobble or grinding!
You might be right, I might take the rear ones off and see how it looks!
  • Replies 242
  • Views 30.4k
  • So had a busy day getting the heated seats back on track! Removed the seats again... With them removed I put the rest of the wiring loom in the right place. I ran it down the centre console and un
  • I've known the door seals have been leaking since I bought the car and since I've just had all the carpet wet vaced I best seal them to keep them fresh! To my suprise the front door seals have been l
  • As said, I got the headlight inserts painted at the same time as the grille so they both got painted satin black. And of course the finished results of both the headlights being rebuilt. And a f
Mine doesn't have the rears on, if you want to see without taking yours off
Think I seen yours, I do quite like it, depending how cold it is tomorrow, I might take them off and give the car a detail and wax, was a couple of cars behind a gritter so want all the salt off my car!
Another slow update, abit cold and snowy outside to be doing much so thought I'd sort out a spare key.
Got a blank blade and cut to match my key code for £8. Went to a local scrap yard and got a 3 button flip key for £5.
Removed the old blade and fitted my new one, then programmed it to unlock / lock the doors. It's just a surf key since it won't start the engine but for £13 it's good to have a spare incase I lock mine in the boot or somthing!
Edited by hutchysrs50
Don't think it was needed just yet but it's been slow starting with these cold mornings, instead of waiting for it to not start all together I thought I might as well get a new battery.
I had a few choices but went with the "OEM rated" battery being Exide, comes with a 3 year warranty instead of the budget 1 year so hopefully it'll be good!
It's also slightly larger so should coupe better :)
Old one coming out
New one in place
Also added some redex to the tank again today and filled up for the second time with super diesel!
With it being cold and getting slight condensation on the windscreen sometimes I thought best to change the pollen filter as well, wasn't to bad, I've seen a lot worse!
Took the grille out today, want it painting perfectly so removed the badge rather than mask it off.
Just dropped it off at the bodyshop to get painted satin black, will be ready to collect Friday :) hopefully I'll have stripped my spare headlights so they can be painted then also.
The badge put up abit of a fight but with the hair dryer on it for a while it pulled away.
No grille at all... Looks alright :D
edited.
Picked the grille and headlight inserts up this morning, could be better but I'm happy over all.
Couple with the beading I had this morning after some light rain last night. It's got a coat of AG HD wax on it.
Another quick one, will put loads of pictures up tomorrow but fitted my projectors tonight (well one of them, will do the other one tomorrow)
Looking forward to this :)
These look great, how much for a set :P
Get selling them on flea bay man :)
Edit.
They look great, little odd but I'm used to seeing mine :thumbup:
I feel mine is slowly turning into yours!
Got my sticker for above the light but had to pick black so mines different :P also putting mine on the passenger side!
Nothing wrong with that mate, shows I'm doing something right ;) I've got a new sticker coming too as mines missing some letters
You staying white letters?
I'm thinking OEM retrofit heated seats next...
Slowly ticking off the optional extras!
Wow these look good :P, how do these stand when it comes to mot time?
Perfectly fine, same as any other lights, they are fully road legal, much better fitting the projectors to hold the HID bulbs rather than most people that just stick a HID kit in standard lights and blind everyone.
I'll find out more tomorrow morning at the MOT station I suppose :P
Yeh, white again. I'd love heated leather but it seems like a lot of hassle. Tempted to sell up but I can't find any other diesels I'd like within the same price range :(
That's a shame to hear, I don't plan on selling mine for a while, it stands me very little and definitely couldn't replace it for the price.
I've sent a few messages regarding the heated seats so hopefully get that sorted around mid Feb.
Got the headlights checked over today and the beam setting done, they wernt far away to start with thought.
The light pattern is perfectly clear and a nice line, will pass MOT no problem at all.
While I was at the garage I thought I might as well get the laser alignment tracking done, both wheels were out slightly but the drivers side more so. Both spot on now so drives that little bit better and hopefully look after my tyres that bit better.
