Tyre pressure
Does anyone know the correct tyre pressure for the sport running 215/45/17 please ?
You should have a special label under fuel cover...
Or see the tire detail..
It's inside the fuel filler cap, the 17inch Rays with low profiles always look flat, especially with the front wheels turned out.
215/45/17  :wonder:
TP
Yeah, look at your flap! :peek:
Or...
The top Skoda Rapid thread in this section, the sticky one, links to the vehicle manual.
Edited by camelspyyder
Or try 36psi front / 34psi rear.
No use looking on the fuel flap, it doesn't give figures in PSI.. When I bought my Rapid I asked the salesman & he didn't know & had to ask a mechanic who said, "32 PSI all round."
A lot of forecourt airlines don't have PSI either.
This country went metric by stealth years ago.
There have been stories on here of Rapids being delivered with around 48 psi in the tyres. (almost exactly 3.2 bar as opposed to 32 psi) -Even the dealers can't get it right on the PDI.
https://www.google.gr/search?q=bar+to+psi
My label has both kPa and PSI , (100kPa = 1 bar)
Therefore for 215/40R17  pressure should be 32psi for both front & rear.
Is 215/45R17 an oem size size on a Sport?
Edited by spiz
Cannot think the label on ours also states load and speed rating, will have to double check in the morning.
TP
If I am not mistaken cars with diesel engines need different (higher) tyre pressure than those with petrol engines...
220 bar or 32 psi, simple.
I will be going for something a bit higher i reckon... maybe like 38 psi all around to start with. running 17's
Are you sure?
220 bar = 22,000 kPa = 3190.83 PSI
I don't think you can pump air into tyre... up to that pressure... :p
...should be 2.2 bar
Edited by 67igor1
Sorry I was going on what the pice above shows, what's the 220?
Are you sure?
read the label - it's 220kPa = 2.2bar
Is this a good time to point out that my pen gauge is calibrated in PSI and kPa?
mine too :)
just don't read the wrong scale...
What does K PA stand for?
Kilo pascals - I.e. Thousands of pascals. 1 kPa is equal to 1 bar.
Sent from my D5803 using Tapatalk
Pascals and Bars are just different words for the same system of pressure measurement.
The weather man reports millibars (like on a barometer) or hecto-pascals  - both are 1000th of a Bar.
Standard atmospheric pressure is 1013.2 millibars ( so just over 1 bar)
A kilo-pascal is 100th of a Bar.
You can measure pressure in:
psi -                                  about 15 to the bar
inches of Mercury(Hb)            29.92 to the bar
or millimeters of Hb         about 760 to the bar.
or to make it easier - you can preset the machine at the garage and wait till it goes ping :)
Whoops, just a factor of 100 out...
