Latest Infotainment version Bolero
1 minute ago, varooom said:
What was your orginal version for this car?
It's highly unlikely to have killed it, but if you changed versions there could be new coding perhaps.
I can look about for an older version, there are also ways with software tools to force a SWDL (Software Download)
You are the only person that has reported this bug/issue.
These are the Screens from before and after the Firmware update
IMG_1261.HEIC IMG_1276.HEIC
  • Replies 998
  • Views 222.7k
  • Version 0490 is now available for Briskoda members. If you are interested please PM your gmail address (instead of posting your request here). Please don't upload it to file sharing sites but feel
  • Have a look in the other thread I posted in. You can update your firmware but you will need to pm aki78 for instructions. I noticed quite a bit of speed increase with 465 / 475. The update process isn
  • Guys, check your PMs.
I have available should you wish to attempt rollback (if it lets you)
S00.1000.01.99
Release="MSTD_EU_SK_P3041"
MUVersion="0171"
S00.1000.09.99
Release="MSTD_EU_SK_P5180"
MUVersion="0465"
S00.1000.13.99
Release="MSTD_EU_SK_P6230"
MUVersion="0490"
that was the old version !20230119_080749.thumb.jpg.fe03aaf94c59f9e5ac1af3fcf5190f0d.jpg
S00.1000.01.99
MUVersion="0171"
S00.1000.09.99
MUVersion="0465"
S00.1000.13.99
MUVersion="0490"
Yes pls send me the Dl link
i have to try if its possible to do an older one
Yes you have 1440 iirc and just need to move around the files on USB to enable it to be seen correct.
Root of drive should be metainfo2.txt
Then 20-30 folders in the next level off the root
Allow 20-30 mins of packing time
IMG_1276.HEIC
sure, but thats my screen now ;)
That was for @Rachetz32 his update is different to yours.
I replied quickly to 2x different posts, and the forum "helped" by merging 2 posts into one (which can confuse)
What should i do now?
How to move around the files on usb?
Your instructions are here
58 minutes ago, varooom said:
Have you tried the reboot or the factory reset on the unit yet?
Can the car see the phone?
Can the phone see the car?
it looks like theres no BT in my car aafter FW Update , that means that the Bolero Unit is not sending BT .
i cant choose the BT menu, when i try to get in there, i get the message "phone is not available"
I took off the compresed files and i go to try one more time ,i hope are work now!
Best of luck!
Thanks!
@mrlittle I'm afraid file system in your unit is corrupted - such behavior is a typical symptom of it. Unfortunately, in such cases SW upgrade or downgrade is NOT possible - at least I have never been able to have it done.
Assuming I'm right, you have two options:
1. replace the unit with same type - remove components protection and reactivate FEC/SWaP codes by Skoda dealer
2. retrofit MIB2 unit - such units can be hacked so on one hand you spend more money on new parts but you don't have to pay Skoda dealer for his services
I'm really sorry but this is always a risk when running SW upgrade 😞
thank you, but i hope, the problem is because of an component detection or maybe a hardware coding helps
Which parts do i have to change when i want to use a Bolero for the Future ?
maybe you can send me Pn
Glove box unit model 5E0035840x where x is a letter A, B, C etc. This is MIB1 unit. If you would like to get MIB2 then you shoul dget 5Q0035840x (x - same as bove) but in this case you must also replace the display unit and, if you want to have new features, e.g. SmartLink enabled, have the unit hacked.
that means, if i have a Problem like you told me with the file system,.... i only have to change the Unit in the Glove box
If you want to remain with MIB1 Bolero - yes
ok that will be the cheapest version with 150€
what will cost a MIB2 complete ?
150€? Have you calculated cost of Skoda dealer services?
Cost for Bolero MIB2 set (glove box unit 5Q0035840x + display unit 5E0919605H + USB 5Q0035726J) is approx 350 EUR plus shipping.
Yes the glove box Unit costs 110€ plus 40€for the Skoda Dealer ?
for 350€plug and play for all to change to MIB2 ????
I believe Skoda delaer will cost you much more than 40€... at least twice as much...
Yes, 350€ for plug and play for all to change to MIB2 Bolero
Do you have the parts to change it to mib2 ?
