"Daddy " Phantom....
Air con now regassed, and ICE cold :) worth every penny to keep on top of it!
  • Replies 536
  • Views 63.2k
  • been a bit quite for Daddy Phantom recently.... not carrying on until I get its issues fixed, but.... its MOT time again.... failed this time....     was mildly annoyed, as I had a
  • we stopped at spa first....     it was a beautiful hot day... in fact over 30C every day we were out there!     Ash and Rose posting at Au Rouge!!     Then on to Germany, we arrive safe
  • think we may buy the proper full size image of this one
looking good.... so nice to be ontop of everything, with all of it working as it should! :)
*sigh.... its still not working properly.... 2nd long journey since the fuel pump "fix" and its still hesitating during a long drive on light throttle, feeling like a misfire but isn't :( I honestly don't know what else to try :( will we be going to the ring in the Alfa again this year?! :( I'm going to look at the throttle body next (fly by wire) can anyone explain how to re set this (re calibrate it?) many thanks.
compression test done, all cylinders the same at 185 ..... so all good!
right, new wiring loom on.... last bit being thrown at it for now... roll on Germany, lets see if it works!
34581163_10204936676452644_8869816548160
Catch can installed today ...
34756916_10204940584270337_7241216914326
Just look at all that gunk down there!
34497847_10204940584990355_6916625607040
Gave it a little clean out.... wow, at least all that crap should go into the can now and not into the inlet!
34601720_10204940584830351_8460995400281
one more thing to do before ring trip... new fuel filter
been out for a long drive today , all ran well :)
makeshift heatshield added to protect the new wiring loom!
loads of room, you could get a fag paper under that!
joined the fabia mk2 vRS group today for a lakes drive, 1.5 hours on the motorway, then a blast back up through the lakes.... fair to say its fixed, no issues apart from a bit of heat soak after a long time full throttle up a hill.... but expected from my crappy intercooler ... all seems well...
got some induction noise arrived in the post  today
well, the car has being going into limp mode when I boot it over the last few days, so finally got to opening the bonnet and found the DV sitting like this! :O
what you can't see in that pic is the left edge of the pipe from the TIP is all frayed and will no longer hold on the DV with a jubilee clip, it works loose due to the angle and tension on the DV ... so I bodged it with cable ties and tape!
all working for now, but guess I will need a new oversized TIP ..... they cost about £100! :O and would be a pain to fit :( I may have to leave the bodge until I can find a 2nd hand one.... will have to be sorted for Germany ....
right next: get rid of that giant air box....
that freed up some space!
S2000 filter in! wwwhhhhaaapppptttsssshhhhh!
Please trim your cable ties off properly. Flappy cables ties are offensive to me.
new boots fitted for the ring trip, as front track tyres were on 3 mm and I didn't want to attempt the karousell with the rears rubbing the arches! :O
shiny new michelin pilot supersports, race construction, designed for some track use and road use, so good compromise and should fit inside the arches!
in 225/40/18 flavour, as you can see a slight stretch on the 9 inch wide wheels, now brings the tyre wall INSIDE the arches, I can tackle the Karousell without fear of destroying the tyre!
the rears with good (German legal!) tread have gone on the front, you can see how much wider the NS2Rs are! :O straight sidewalls, you can see where its been rubbing (No damage....) and still 225/40/18s!
some tread now, should work in the rain again!
I have also bodge fixed my broken TIP... instead of £100 for a new one, I have used a £5 breather hose from china a 90 degree join, and a few cable ties etc, and the forge 007p is back in! The standard dv I put on fitted the worn TIP but was loosing 0.1 bar across the range.... 007p back on and full boost restored! Its not elegant, but I don't care what it looks like under there its working!
test driven today... I can confirm the new DV set up works perfectly... and the rear tyres no longer catch.... bring on the ring!
Saw your old vrs estate the other day, still looks good :blush
awww, glad its still going strong, was a fantastic car... If I could have bought it back when we got the Alfa I would have!
Think the owner lives somewhere in the Hebden Bridge area as that’s where I saw it and it was for sale at a local garage in Hebden a while back
because racecar...
page_5269775-f4cad3df194111424e4e3e816ac
"Porsche taken like a king!"
:D
:D
I haven't heard that for a while!:D
