Rear Number plate LEDs
On ‎10‎/‎02‎/‎2016 at 13:17, langers2k said:
An AE rev should be able to support LEDs without load resistors. It's a newer part than the P/Q/R rev's :)
My 2012 model has bcm part number 1K0 937 087 AG
So is ag newer than p and q etc..what a strange way they have of adding revision numbers.
Looks to be, it's normally running SW:0709 which is newer the SW:06xx found on p/q versions. I think they typically do a-z, aa-az then even ba-bz! CAN gateways are upto BL now ;)
8 hours ago, VWGDT said:
If you have ODIS, the SVM code is 31DB9 for FL cars. It would not accept this code on my 12 plate J519 ending AB Z00, I will update it to the latest software and retry.
Have you tried changing byte 17, bit 7 in the BCM? Are you using ODIS-s or ODIS-e?
g
Edited by FlyingSpanner
