How do I access the VCDS on my Skoda Octavia
What do i need to do.
Edited by davitc
You mixed up some terms obviously, VCDS is software running on PC, and you need original cable to connect your PC to your car to do software tweaks.
Edited by Croat
How expensive are the software and the interface?
About £260 ish - but its a one hit - lifetime updates, no cost setup.  Mine's been running for years perfectly.
ilexa sell it.  So does gendan.
Thanks for the info. 260,-... I'll check then first how much I need it ;)
Got mine on a group buy a few years ago now. Worth it's money IMHO, adding options on my mk3 has alone saved my Over £600 of options!
@ M12MKD
What options did you add and in what way did it help to have the VCDS?
I'm now looking for ways to fit my O3 with navigation on top of the existing Bolero/Canton or instead of it.
Some details: http://www.briskoda.net/forums/topic/389835-octavia-3-navigation-upgrade-options-ideas-thoughts/?p=4540882
Do you think the VCDS would be enough to facilitate the software coding needed to replace the Bolero with e.g. Columbus?
Edited by wlange
You could always look up the VCDS Map that shows you where Briskoda Members that have VCDS are located and then contact them.
Most like myself would do it for either free, few beers or a bit of cash. There are quite a few now with Full VCDS especially in the UK.
Looks like your in Notts, whats your favourite beer? Will be collecting my Octavia next month and want a couple things activating if your up for it?
Did someone make such upgrade (still maintaining all the canton functionality)? What would I need to do / is there a guide or something?
As for the beer, that could be safely provided in (in)appropriate amounts...I'm now in Munich and could be your guide to Oktoberfest ;)
i'm waiting on an OBDeleven device to arrive - only 55 euros rather than 260 pounds
http://obdeleven.com/
seems to get decent reports from the golf7 forums about capabilities
Where do I find the VCDS map?  :happy:  :thumbup:
Favorite beer is the wet variety basically anything but Guinness. I can probably help, My range of mods so far quite limited - Changing Lights behavior Coming Home, leaving etc. Done a few Blu-tooth installs. So you might have to do some homework and find out what the coding requires.
There were a few I wouldn't mind, mainly cornering fogs, remote close for boot (ordered power boot) and mirror dip in reverse, traffic sign recognition. Think that's it.
It's worth mentioning before people go out and buy vcds that you can seriously brick your car if you don't know what you are doing and get it wrong!
Actually that is very hard to do with VCDS, you would have to try to cause problems. Vag can pro however can do real damage.
Sent from my D5803 using Tapatalk
I dont wish to **** on anyone's chips either but in the interest of transparency, and full disclosure, if you engage with someone to enable features on your car, you should be very clear that it is possible you could end up with a car that wont work, however unlikely that is, it's still a risk.
It's just risk/benefit, and it's definitely a really useful tool that can save you a fortune, not just enabling, but diagnosing. Most dealers charge you just to pull up fault codes nowadays.
Edited by Mallettsmallett
Surely you invalidate the warranty also?
Is there an access log, so they can see you've been changing settings?
How could changing settings which can be changed invalidate the warranty?
If you have it and know how to use it yes it's easy but if you get into the long coding and change something you shouldn't, oh bother!
Just putting it out there for people to be weary if they are going to dabble with things. There are some great guides on here to follow though.
If you just blindly start pressing buttons you will have some problems. But you are very unlikely to damage anything or render it undriveable. Even if you randomly changed things in the long coding (with the exception of 1 or 2 very specific things) working out what is was originally set too isn't going to be too hard.
Even doing things like changing good old byte 18 can be sorted with the dealer kit or VCP.
Sure thing don't disagree at all with you! But you do know what your talking about, have lots of experience and access to people/ other equipment who can help if it goes wrong.
The op however sounds a novice and may not be so fortunate and end up doing more harm than good in desperation if thing went south.
Just want new people to be careful.
There was a guy on here the other week who asked what oil to use as his oil lights come on and he hadn't checked the oil ever in 15000 miles as it gets done on a service doesn't it!?!.....what's easy/normal for some is quite different for others.
I was always told basic rule is to write down the original coding or screenshot it before changing and then you can always put it back to EXACTLY what it was before tinkering.
