Lofty's Sprint Yellow Fabia vRS Mk1 - "Project Daffodil"
That looks so class... Some attention to detail .  Well done
If you seen my car Lofty you would cry... ! I feel so unclean looking at those pictures :blush
  • Replies 775
  • Views 137.6k
  • In the style of Jim from Friday Night Dinner.... "Hello All....."   It's been a while, nearly 12 months in fact since I gave a proper update, it's been a busy old year. We moved house mid No
  • Update time. Nothing exciting like actually starting the engine up yet but part of the whole getting ready to move house bit means I needed to sort the loft out, and there just happened to be the fron
  • Update time!   Back in post #52 you will recall a picture of a rather grubby looking 1.9 PD engine from a Fabia vRS. This has been purchased for a number of reasons, most of them totally log
Glad it’s still an ongoing project, looking lovely.
Hey my fellow Skoda people.
No news from the trimmer, he said he was flat out and of course i said "no rush" so i'll be back of the queue, ho hum.
In the meantime i have yet another distraction arriving in the next day or so which will no doubt delay the completion of the Yellow Fabia.....
A little old British lady (51 yrs old - GILF??) is coming to live in the garage with the bright and bold teenager from the Czech Republic, lets lope there is harmony?
Matt
Wonderful work.
I've now been over the seat twice with the following.
Light spray of 1:10 dilution Bilt Hamber Surfex
Good scrub with a strong mix of Autosmart Bio Brisk
Then extracted with hot water in the Bissell Spot Clean Pro.
Currently on my patented Drying Max 2000 Drying table on the patio..
It "should" be ok to go back in the car now, just waiting for a new seat belt buckle/stalk to come from TPS as the old one was scratched up badly.
Seat runners are all painted up now and waiting to be fitted back on the seat.
Plan is to get the driver seat back in, then the fully valeted rear seats and then finally we can get back onto the engine bay. I have the old engine loom removed and the new Genuine one ready to go back in, I'll do that, then change the cam sensor for a new one and go for another fire up.
11 minutes ago, Lofty said:
TPS have been in touch, the remaining piece of seat plastic side trim has now come into stock having been on back order for weeks and weeks - I can't imagine there is much call for people buying obscure bits of plastic trim for 15 yr old Fabias nowadays, so i'm collecting that over the weekend.
I've decided to give the seat another going over with the upholstery cleaner and getting it as mint as possible, then it will be going back in the car next week - carefully as I don't want to scratch up the new plastics in the car and on the seat.
In other news I have done a "thing"....
In the correct Skoda Mint Green as well. Initial reaction on the Whatsapp group chat was a little less than complimentary, but it's not actually destined for the car. Just a hose reel for the garage wall.
Pity really as it certainly is a stand out colour.
More soon
Almost fantasy green 😂
Small update (make the most of it fellas!)
Rear seats back in after 12m of being in dry dust free storage, check out the magnificence that IS the middle head restraint...
Drivers seat all in on the repainted subframe..
Oh and we got the engine running.... for a bit, till the lift pump in the tank decided it quite liked retirement and handed me it's notice. Dang it!
New lift pump is on it's way and i'll try and get some video of it actually running.
Edited by Lofty
Love that this has been updated! I've loved looking through this project and watching it all come together since I joined the forums! :thumbup:
About time we had an update.
A couple of posts ago i said we had finally had the engine running, until the lift pump in the tank decided to hand it's notice in and down tools.
Well, you'll be pleased to learn (if not pleased some other fun feeling), that i have fitted a new lift pump, cycled the ignition a few times to bleed the air out of the fuel lines and all is gravy again. As in she runs. Again.
I celebrated this momentous task by taking things off the engine - as you do......
The boost pipes i'd lovingly repainted (probably about 4 years ago) in crackle black were no longer doing it for me, i needed some blingly colour in the bay, so I did yet another "thing"..
My new local powder coating emporium - Project Powder Coating, Brierley Hill - have done me proud again, stripped and blasted, powder coated in Mint Green (RAL 6029) then coated in Gloss Lacquer Powder, they are mirror smooth, and tough too!
The RAL 6029 is the exact match for the Skoda Mint green in the original Badge, and the brake caliper colour, so it ties in well with the SEAT Sport Strut brace in the bay, and the Skoda badge on the engine cover..
Et Voila ....
Next jobs are to get the boost pipes connected back up, wheel arch liner in, and then fit the headlights up.
It might even be off the axle stands soon and moving about under its own power - last time it did that was September 2016. Time flies when you're having fun as they say
Liking the look of those pipes Matt. That's the kind of thing I would consider doing if I wasn't such a stickler for stock original! :biggrin:
Well, she's proving to be a challenge for sure this one!
I'm still hunting down a running problem which only manifests itself when the car is hot and up to normal operating temperature.
So, she starts perfectly fine from cold, revs cleanly, no misfires or anything daft. Idles fine. Once it's been running for say 20 mins it'll cut out as though it's run out of fuel. Then refuses to restart. It tries to start but it's literally as though the tank is empty.
So far we have replaced the following with new items.
Lift pump in tank
Tandem Pump
Crank Sensor
Cam Sensor
Fuel Temp Sensor
Coolant Temp Sensor
Engine loom
The injector loom was new, along with the DSSR injectors when the engine was put together. New injector Bosch seal kits fitted as well.
Cam timing is spot on, torsion value flicks between 0.0 and -0.5
I'm now in the realms of changing the "109" relay under the dash as it would appear this could also be an issue? Struggling for motivation at the moment with it to be honest for obvious reasons.
I've run VCDS and there are NO faults showing anywhere, nothing, nada, zip, zilch. Annoying as hell.
Anyone have any ideas before i reach for the matches and a gallon of unleaded..........
Matt
Not a bad plan. Position 15, bottom right on the relay plate.
Yeah i've got the relay from TPS, starting to remove the lower dash this evening to get it swapped over.
Wish me luck Wino - i may need to pick yours and Ross's brains some more as we go on!
Great to see you’ve still be working on it. Shame about the running issues, but  I’m sure you’ll get it sorted
Awesome project mate. I have been reading this topic from beginning to the present in these last two hours. It's just... amazing. The hundreds or thousands of hours you have put in this car!!!
Just a question that could help me. Where did you get the "genuine Skoda accessory boot bags, and a new genuine Skoda boot liner"? Because they look awesome and I could definitely use them so I can free some boot space. Half of it is taken by my tools, but I reckon I'll have enough for some wrenches or screwdrivers in those bags. And the boot liner! Clean.
The boot liner i bought years ago from TPS, not hugely expensive from memory. Now no longer available I'm afraid. Same story with the boot storage bags, got them off a friend who had a vRS Fabia from new then broke it for spares, they'd been in his boot for 13 years and never been used, so thought they'd fit in just fine on mine, and continue not to be used...
Haven’t been on here for a few years. Was great to see your thread again.👍 I have a Vrs itch again….
Me, whispering from the side: do it, buy it... :giggle:
Wow, such an amazing build with great attention to detail. Kudos to you on your build, cars and garage too...
