Lofty's Sprint Yellow Fabia vRS Mk1 - "Project Daffodil"
Neat solution to the towing eye :)
  • Replies 775
  • Views 140.6k
  • In the style of Jim from Friday Night Dinner.... "Hello All....."   It's been a while, nearly 12 months in fact since I gave a proper update, it's been a busy old year. We moved house mid No
  • Update time. Nothing exciting like actually starting the engine up yet but part of the whole getting ready to move house bit means I needed to sort the loft out, and there just happened to be the fron
  • Update time!   Back in post #52 you will recall a picture of a rather grubby looking 1.9 PD engine from a Fabia vRS. This has been purchased for a number of reasons, most of them totally log
Cheers Charlie, hopefully never need it, and fingers crossed it'll be robust enough not to rip to bits if I do.....
Yes hope it doesn’t have to be used. Should be more than adequate though.
the one I have is a bar with a smaller bolt going through it and that was enough for my car to be towed
Fitted a new bonnet catch today as the old one had got a missing microswitch for the bonnet open warning, so at least I’ll not have a random connector floating about.
981FC718-5D97-42CA-9DE8-BCF36137AEDD_zps
I’ve made a start on the battery fitting, the BLT versions generally have a much more exposed fuse board set up than the ASZ so I’ve stripped it all down to its component parts, cleaned all the link fuses up in the brick acid then with the wire wheel in the dremel.
Need to order an “upper battery case” from TPS as mine is badly marked and gouged from years of use. I’ll get that ordered for next weekend, then hopefully get the battery in and wired up totally.
Edited by Lofty
  • 4 weeks later...
In a word... WOW! Just read through the entire thread (took me a few hours! :D) your work is very impressive! Well done sir!
More updates coming soon, but in the meantime I can update you on the rear spoiler jobby.
I located a used rear spoiler from a member on here, which had been removed from a car years ago due to it coming loose, it’s been blown over at some point with a rattle can but that’s no bother as it’s going to be stripped back before being painted and dipped.
Top surface..
68469D33-124F-46BF-A72C-8D30BC2C844D_zps
Doesn't look too bad till you start flatting it and all the crazing shows up..
I’ve ordered some more sanding discs for my DA so I’ll soon sort that out.
The underneath of the spoiler had to be stripped of all the old adhesive and gloop
8291BFEC-8766-42A5-938E-1F786B572A08_zps
AF5F740F-3CB0-4778-B958-4E98E8B70556_zps
you can see there the groove that has a thin bead of bonding adhesive on it before it goes back on the car. The underneath of the spoiler will be painted and carbon dipped up to that line so it’s a seamless edge when finished.
Next up was the ball ache of removing the old spoiler off the Daffodil. Managed it though with judicious use of the heat gun and burnt fingers...
6C6366C1-7881-4DDE-9E9C-D7FCBA401355_zps
All cleaned up and machine polished. The surface will be given a further wipe over with solvent panel wipe before the spoiler gets bonded back on..
B9C5E846-5AD5-463A-B67A-04A627F81862_zps
I’m heading to TPS tomorrow to collect all the earlier style of battery box plastics as I’m converting it to run the ASZ style of battery box, complete with the much tidier battery cover, which can then also be carbon dipped to finish the engine bay off. I’m having to replace the link fuse bar, main battery lead as well as the plastics so all will be with new parts...
I will get pics of the battery box conversion when it’s underway.
Edited by Lofty
Looks lovely mate. Was the battery box expensive? I could do with replacing mine as most of the clips have broken
Thanks Charlie, yeah it was a bit expensive, depends which bit is broken on yours I guess? The main outside casing was £40 plus the vat, the dear parts are the fuse links etc
The top cover and the part with the fuses. Are you using a pd160 intake? It’s really really tight against the battery cover, so can get scratched easily
The top cover is the cheapest part at less than a tenner, the board where the fuses go is about £40
Yeah pd160 intake here... fitting it soon
That’s going to look sooo good once it’s done
Just had a random thought, carbon dipped wind deflectors?
Never been a big fan of them tbh, prefer the smoother lines without.
Loving the updates, will be a machine when it's done.
Spoiler is finished from a sanding perspective. I hate sanding. That is all.
Off to the dippers next week, I’ll post more enjoyable updates when I’ve something shiny to show you all.
(still hate sanding by the way....)
Wow
Fixed broken picture link now. 😆
Edited by Lofty
